Lateral stress = knock?
Well, its pretty nasty outside around here, so maybe I can get some opinions on whats going on before I brave the elements...
Sometimes (and I do mean sometimes, its not very common) I'll get a knock type of noise when I put a lateral load on teh car while driving (eg: oing around a corner). When I push on the **** end sideways I can fairly readily product this noise. To my ear it almost sounds like the c-clips in the differential (havent taken down the GM rearend before, but it cant be TOO much different than a ford 8.8). The only other thing that would make sense to me would be maybe somethin to do with the panhard bar?
Re: Lateral stress = knock?
Tighten the bolts that hold the rear sway bar end-link brackets, to the chassis. Put about 55 ft-lbs on them. Also, take a look at the top mounts of the shocks; you'll have to pop your back seat out and pull the carpet back.
Yeah, I've been meaning look at the shock mounts; didn't even think about the endlinks though. When it gets a little less wet out I'll probably drop the wheels to check the brakes anyways, so that would be a good time.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
