ball joint checking gauge
Old Jan 30, 2008 | 07:30 PM
dp149's Avatar
Hi,
Was wondering if someone could tell me if I am using my ball joint checking gauge correctly on my 85 TA. I have the wrench part clamped to the spindle but I am not sure the proper place to put the dial indicator (which is attached to a movable arm to the wrench part). Where should I place it to test lateral and radial movement?
thanks
Old Jan 30, 2008 | 07:39 PM
Re: ball joint checking gauge
Somewhere on the control arm.
The ball joint is half pressed into the CA, and half bolted into the spindle. You're watching for movement between the spindle half and the CA half of it.
Easiest way to check those is to jack the car up by the control arm, just enough to get the wheel to clear the ground far enough to get a 2x4 or the like under it; and use that as a lever to lift the wheel, spindle, and strut. Watch the ball joint right below the spindle where the nut is. Some BJs have the grease fitting installed such that it moves in such a way that you can see it. However far it moves, that's how much play you've got. Eyeball is usually entirely enough precision.
If it's got more than about 1/16" of play, it's getting old. More than 1/8", don't let the car back down without replacing it.
redmaroz
Apr 25, 2017 07:14 AM
zayne0
Aug 24, 2015 07:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
NBrehm
Aug 5, 2015 07:57 PM
