lowering
Old Mar 8, 2008 | 09:41 AM
gta87transam's Avatar
lowering
What would be the easiest and cheapest way to lower my car an inch or two?
Old Mar 8, 2008 | 09:43 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: lowering
lower springs
ebiach prokit or hotchkis for 1"
ebaich sportlines or inatrax for 1.5 to 2"
looking around for the best price you will find them all for about 200 bux give or take a few
Old Mar 8, 2008 | 10:43 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: lowering
You'll want to do shocks when you lower it as well. The stock shocks (or OEM replacements) won't last with the lowerings. You're ride and handling will suffer without good shocks with the springs.
Old Mar 8, 2008 | 10:58 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: lowering
Also need to get an adjustable panhard bar, otherwise your rear won't be centered after you lower it. You might want to look into some LCA relocation brackets too, but they are not required.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
MrPackstin
Oct 25, 2017 08:09 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
92projectcamaro
Sep 29, 2015 07:07 PM
