do polly bushings help u hook up
Old Mar 16, 2008 | 05:50 PM
cory's Avatar
Car: 1985 trans am WS6
Engine: 350cam,carb,intake,headers,3"exuast
Transmission: T5,
Axle/Gears: 3.73 posi disks
hey guys im rebuilding an 85 t/a and i want to be able to hook up well im putting SFCs in i was wondering if any polly bushings would help??
Old Mar 17, 2008 | 04:32 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: do polly bushings help u hook up
Are you talking about replacing the stock rubber bushings in the LCAs and PHB with poly bushings or buying aftermarket LCAs/PHB?
Old Mar 18, 2008 | 06:44 PM
cory's Avatar
Transmission: T5,
well i wanted to just keep the stock LCAs and PHB and buy polly bushings
Old Mar 18, 2008 | 07:15 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
You can do that, but I don't think you'll see as much benefit as if you were to buy aftermarket LCAs/PHB. The stock pieces are pretty flimsy and flex whereas the aftermarket ones do not. This is where most of the improvements in traction comes from. LCA relocation brackets will help you gain better traction if you are planning to lower the car You may want to invest in some better tires as well. All the suspension in the world doesn't help if your tires won't hook.
Also, you don't want dual end poly on the LCAs in a street driven car. The poly doesn't allow the LCAs to work as they were designed.
Old Mar 19, 2008 | 09:48 PM
cory's Avatar
Transmission: T5,
thanks for the advice
Old Mar 20, 2008 | 11:53 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
If you aren't worried about the cornering characteristics of the car much, you can box the stock LCAs and install poly. I'd say if you installed rubber with the boxed LCAs, you'd see better traction.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Gordonr1973
Sep 29, 2015 11:59 AM
