Manual rack kit
Old Apr 2, 2008 | 05:34 PM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Manual rack kit
Hi there!
Where can i find manual rack kit for 88 Firebird with V8 engine ??
Best regards
WASyL
Old Apr 2, 2008 | 07:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Manual rack kit
Do you want a manual rack or a manual steering box? Third gens don't have rack and pinion steering.
Old Apr 3, 2008 | 02:34 AM
WASyL's Avatar
Re: Manual rack kit
yes i know they don't but i found this:
http://paracing.com/product_info.php...ac8f024f9a1bec
but they do not replied on any of my e-mail
best regards
Old Apr 3, 2008 | 06:44 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: Manual rack kit
Those rack and pinion kits are designed to be used with an aftermarket tubular k-member. I don't know if they can be adapted to a factory k-member.
Old Apr 3, 2008 | 06:54 AM
WASyL's Avatar
Re: Manual rack kit
i will be useing SPOHN k-member so that's not a problem, but i still don't know where to find this manual rack kit coz' PAracing is not responding
best regards
Old Apr 3, 2008 | 07:13 PM
scarab88's Avatar
Re: Manual rack kit
try bmrfabrication.com
Old Apr 3, 2008 | 07:16 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: Manual rack kit
well you need to know which rack fits best. ask the manufacturer of the K member. If you can use a manual pinto or Mustang rack then summit has rebuilt ones for cheap!
Old Apr 3, 2008 | 07:17 PM
runt's Avatar
Re: Manual rack kit
go check out thunder racing they have them hope that helps you out
Old Apr 3, 2008 | 10:22 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: Manual rack kit
out of all the places, racecraft inc was most helpful, and solidifed my purchase with them.
pa racing and bmr also offer parts.
are you buidling a drag setup?
rack and pinion is the last straw for weight and space. not something you wanna do for a car you drive all the time, IMO.
Old Apr 4, 2008 | 02:30 AM
WASyL's Avatar
Re: Manual rack kit
Thanks for sugestions, i'll ask at Spohn which one will fit, i'm not building drag, the target is to rebuild this old crap and sometime go on drag or drift, and for drift i need a bigger turning angle and here comes manual rack which should help.
best regards
Old Apr 4, 2008 | 02:40 AM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
Re: Manual rack kit
with a manual steering rack, it'll run into the first 2 primaries on the driver side. A custom header would have to be made to fix this.
Old Apr 4, 2008 | 02:43 AM
WASyL's Avatar
Re: Manual rack kit
you mean exhaust haders?? I'm useing Edelbrock TES Tubular Exhaust, they won't fit ??
best regards
Old Apr 4, 2008 | 04:07 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Re: Manual rack kit
if you are going to drift, you DO NOT want a rack and pinion, and manaul makes it worse.
the wheel is going to come back at 200 mph and you wont be able to grab it when the wheel spins free. mechanical force at its best.
with power steeering, the pressure of the fluid eases the steering wheel back so you can catch it.
caution, so you know what you are getting into. you might not like the outcome.
thats the beauty of fabrication.
couple of steering joints and a steering brace and you can work around it, or re work the header.
it can be done.
Old Apr 4, 2008 | 07:04 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: Manual rack kit
All the NASCAR drivers use power steering. Unless you're building a drag only car you'll always want power steering. The main reason for converting to manual steering is the weight loss. The second reason is to clean up the front of the engine by removing all the power steering hydraulic components.
Drone358
Dec 10, 2015 08:16 PM
SG91camaro
Sep 5, 2015 10:27 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
