Pitman Arm!?!?
Old Apr 3, 2008 | 07:29 PM
Alexan89's Avatar
Car: 89 CAmaro
Engine: 305 TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.45
Pitman Arm!?!?
I got 89 camaro 5.0, and i need a Pitman arm for it, but i cant find it anywhere! I went to NAPA, and looked on Ebay, noone caries those! Does someone know the place where i can get it?
I will try dealership 2morow!
Thanx, Alex
Old Apr 3, 2008 | 08:25 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Pitman Arm!?!?
It's considered a non-wear item, so you may have to resort to the dealership.
JamesC
Old Apr 3, 2008 | 08:28 PM
Alexan89's Avatar
Car: 89 CAmaro
Engine: 305 TBI
Axle/Gears: 3.45
Re: Pitman Arm!?!?
HEY! Thanx for reply!
Look, when i move my wheel, i get some play, and it comes from where Pitman goes into Center Link! I bought new center link already, and going to do alighnment on my car 2morow, and i thought that i migth as well get Pitman arm, and it turns out i cant!!
I will see if new Center link Solves the Problem!
Old Apr 5, 2008 | 08:51 PM
Alexan89's Avatar
Car: 89 CAmaro
Engine: 305 TBI
Axle/Gears: 3.45
Re: Pitman Arm!?!?
Yup, center link fixed it!
Old Apr 5, 2008 | 09:00 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Pitman Arm!?!?
That's the second time I've seen someone think their pitman arm is worn out. As stated above, it's a non wear item. The only time it needs to be replaced is if it's damaged (bent).
Now older cars such as first gens had a ball socket as part of the pitman arm. These could wear out.
Old Apr 6, 2008 | 10:35 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Pitman Arm!?!?
The first gens also had both idler arm pivots on the idler itself. This makes the 1st gen center link a non-wear item.
I've even seen mechanics state that a 3rd gen requires a new pitman arm (because of play at that joint). With the way center-link/pitman-arm/idler-arm pivots get moved around between the years it is an easy mistake to make.
RBob.
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
