V-6 Suspension V-8 in bay
Old Apr 12, 2008 | 03:03 PM
8CylinderAddict's Avatar
First i'd like to say that im new here and this is my first post. So i apoligize if my ettiquette isn't the norm. Ok now background first and then my question.
I have a 1982 Berlinetta, it was a V-6 car. After 235,000 the V-6 was retired as a boat anchor (no offense to any v-6 owners ). A 350 was dropped in place of the original and the tranny too. As is easy to figure out the front end likes to scrape pavement every once in awhile at the cost of my oil pan. I was wondering if its possible to put in the front components from a Z-28 suspension of the same year to help bring the nose up some, and is this possible without any major fabrication i.e. welding. I've been thinking about this solution to my problem since the small block was put in but nobody I know has tried this, Hopefully someone has here on ThirdGen and any opinions/experiences/wisdom would be appreciated. Thanks
Old Apr 12, 2008 | 03:14 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: V-6 Suspension V-8 in bay
i think all you need are v-8 front springs . good luck .
Old Apr 12, 2008 | 03:16 PM
Yeah thats what i was thinking too, thanks for the reply
Old Apr 12, 2008 | 03:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
just springs, maybe grab a better sway bar too
Old Apr 15, 2008 | 09:40 AM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Yeah all you need to do is swap the springs to bring the nose up but I would look at the condition of the shocks as well and replace them while your at if they look cruddy.
Old Apr 16, 2008 | 08:04 PM
thebufenator's Avatar
Car: Firebird - Camaro
Engine: 2.8L - 6.3L
Axle/Gears: 3.42 - 3.23
Berlinetta's did not have rear swaybars I dont think.
The fronts are also pretty small
Get the larger swaybars, 36/24.
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
