Koni yellow vs KYB gr2
Old Apr 17, 2008 | 07:54 AM
Method_z28's Avatar
Car: 92 camaro z28
Now how much bigger of a differebce are these yellows gonna make compared to my KYB's?
Old Apr 17, 2008 | 12:53 PM
SteelTownMadDog's Avatar
Re: Koni yellow vs KYB gr2
That's kind of a vague question. If you plan on doing plenty of road racing/autocrossing, then you need the yellows. If it's just a street cruiser, with the odd trip to the track, then the GR2s will be fine.
Old Apr 17, 2008 | 03:07 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
KONIs are great. That's all I know. haha
Old Apr 17, 2008 | 04:24 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Because I autocross my car, I plan on buying the Koni yellows as soon as they are in stock. I have very short commutes to work and school (maybe 5 miles to work and 2 miles to school) so I don't car much about a rough ride.
Old Apr 17, 2008 | 07:58 PM
anthony64ss's Avatar
Car: 1984 Z28
Engine: L31
Transmission: WC T5
Axle/Gears: 10 bolt 3.73
No comparison IMO.
They actually have rebound control for one.
Old Apr 17, 2008 | 09:15 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
LMAO!!
From what I've heard, the KYBs wear out fast if they are paired with lowering springs.
Old Apr 17, 2008 | 11:15 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Me too, except I do know the ones that were worn out, that used to be on the car.
Not a ruff ride at all, I have the fronts set pretty firm, and the rears set one click from full soft.
Old Apr 18, 2008 | 08:45 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Quite abit of difference.
The GR-2 are a middle of the road piece that does not give stellar performance in any category but does well in most. If you want a sensible solution for a reasonable price they will do alot better than the common gabriel and monroe junk.
Even low end Koni are a step above the rest. I find they lose some performance a little faster then expected but like anything else you get what you pay for and yellows are pretty good bang for buck thru out their service life.
What else have you replaced on your suspension? If nothing, eg: its all old stuff, I'd get the GR-2s front and back and take the money I saved over the konis and replace every moving part in the front and rear suspension. Then you would notice a difference...
Old Apr 21, 2008 | 12:20 AM
topless89's Avatar
Car: 89 RS Convertible
Engine: 305 tbi
Transmission: 700R4,B&M friction,Transgo shiftkit
Axle/Gears: 2.73 LSD
you need to take into account that koni's come with a lifetime warrantee. i replaced my Gabriel's with kyb's and there was almost no difference in feel even though the old ones were so worn that i could push the shaft in and out easily. and now after 2 years on the road they're showing pretty bad signs of wear.
Old Apr 21, 2008 | 07:35 AM
iansmusical's Avatar
Car: 91 Firebird & 02 VW Polo TDI
Engine: 3.1 V6 & 1.4 3 cylinder
Transmission: Auto, M5
Axle/Gears: Stock
I was just thinking of replacing the suspension on my 91 V6 Firebird with KYBs but after hearing that, think I'll look for another brand as 2 years is nothing!!!
Thanks for that!
Ian
Linson
Oct 24, 2025 02:00 PM
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
tcflint
Sep 27, 2015 05:58 PM
