more suspension work.
Old Apr 22, 2008 | 08:28 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
ive got the car running very well cutting 60s in the 1.4s the car goes straight but is pretty twisted. would i benefit from an aftermarket sway bar like the spohn drag kit? what else can i do to go quicker?
Old Apr 22, 2008 | 08:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: more suspension work.
some people here use the wolfecraft anti-roll setup, seems to work well. I believe Greesemonkey uses it
Old Apr 23, 2008 | 02:04 PM
stiletto's Avatar
Car: 85z28
Engine: sbc
Transmission: th400
Axle/Gears: 3.80 gear 35 spline axles
i have a wolfe anit roll bar, my car cuts 1.30-1.33 60ft all day
Old Apr 23, 2008 | 05:43 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
thing looks like its getting out!
cage? i have a 1" sway bar on the back of mine with different than stock end links.
my car leaves pretty strait, but you can only do so much without a cage.
Old Apr 23, 2008 | 07:19 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
its got a cage and subframe conectors, umi lca's with relo brackets, jegster torque arm, and umi panhardbar. best 60 was like a 1.45. still want to go quicker, the 1.45 was on a 100 shot. on my 175 it cuts low 1.5's would think it could go 1.40 on the 175
LT1Formula
Oct 8, 2015 08:34 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
