whats the biggest rim??
Car: 87z28
Engine: 70 LT1
Transmission: 350 TURBO BUILT BY B&M
Axle/Gears: 12 BOLT POSI
whats the biggest rim and tire for my car it is a 86 z28 the original tire size is 215/65/hr15 I want to go to a 16 or a 17 inch rim but i dont want to hit the fender when i turn the steering wheel. i know its the issue with the front tires
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: whats the biggest rim??
You can safely run any stock 3rd gen wheel/tire combo (245/50R16s). You can run 17x9.5s (275/40R17s) with 4th gen offset if you use 2" bolt on spacers front and rear (or a 4th gen rear and 2" front spacers, like I did). You can also run 17x11s with 315/30(or 35, can't remember)R17s on the rear with the spacer or 4th gen rear, but it's a much tighter fit.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
