wheel hop
Old May 13, 2008 | 08:59 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
wheel hop
Just went to the track Saturday, and got great traction with my new ford 9" and spohn front coilovers. But I did notice a little wheel hop? I have hotchkis control arms, hotchkis rear sway bar, spohn adjustable torque arm adjusted to -3 degrees, KYB AGX rear shocks adjusted at ?, and spohn rear control arm relocation brackets set to the bottom hole, and ran my mickey drag radials at 20 psi. So what can I adjust to eliminate my little bit of wheel hop?
I also developed a sqeek in the right of the rear end when turning right, it sounds like a bushing or somthing rubbing, could it be caused by the spool ? I need to put the car back up on jack stands and check it out.
Old May 13, 2008 | 10:59 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Re: wheel hop
with all those adjustable suspension components you may just need to find the right set up. may take a few runs to get it right.
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
