V6 handling and LSD Questions
Old Jun 4, 2008 | 04:02 PM
kukerdan's Avatar
Hello, I am not sure if i have open or limited slip diff in my car,
probably open, as its a V6.
My question is, I wanted to throw in an IROC Z rear end,
to get LSD, and Rear discs in one shot,
However, is this going to hurt my handling barreling around really
sharp turns like I can do now?
Old Jun 4, 2008 | 04:25 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
Re: V6 handling and LSD Questions
it might most iroc rear ends are posi nothing wrong with posi great for straight aways limited slip in my opinion is better for cornering the disc brakes are much better tho
Old Jun 4, 2008 | 04:46 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
LSD is a good thing, it'll help you power out of corners. Just make sure you get the same gear ratio.
Old Jun 4, 2008 | 04:58 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
shut up.... POSI AND LSD ARE THE SAME THING!!!!!!!!!!!!!POSI TRACTION IS GMs name for LSD....o my god.....dude get a lsd rear from a iroc or forth gen camaro with disc brakes and lsd and use the search ithere is alot of info on what ones to get and it will help your handling...
Old Jun 4, 2008 | 05:32 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Dumb reply. You do know that a Limited slip is the same as positaction (posi).
Old Jun 4, 2008 | 07:46 PM
kukerdan's Avatar
ok, as long as its not going to cause one wheel to hop or lock around a corner.
Old Jun 4, 2008 | 08:25 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
The only thing that would hurt you would be a spool....or a stuck locker. A LSD (or Positraction as GM calls them) will help you.
Old Jun 5, 2008 | 02:19 AM
Guest
Guest
Posts: n/a
The posi will tighten the car up and make it a tad harder to rotate through and out of a corner. the nose of the car will push more and you'll have to put more wheel into it to turn when under throttle.
Old Jun 5, 2008 | 03:02 AM
RacerX13's Avatar
Car: 88 Formula
Engine: LB9
Axle/Gears: 3.45
So could an open diff car work well or better with more rear roll stiffness? Like say a V6 autocross car?
Old Jun 5, 2008 | 04:40 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Look into a TR2 differential. They are made specifically for cornering cars.
Old Jun 5, 2008 | 08:32 AM
mario82z28's Avatar
posi is power to both wheels at the same time all the time limited slip changes power side to side NOT the same...
Old Jun 5, 2008 | 09:56 AM
Guest
Guest
Posts: n/a
Wrong...You are posting bad info.
positraction is limited slip in the corners. It is a cone style clutch locker with spyder gears and is spring loaded pressure just how much the clutches allow slip in tighter corners.
V8's will waste Auburs and Eatons quicker and I recommend the T2's, however, with a low hp V6? I had one that handled EXTREMELY well and I had an Auburn PRO (the stiffer springed version) in mine that is lastin fine.
Dean (V6RSR)
Old Jun 5, 2008 | 10:04 AM
DJP87Z28's Avatar
[QUOTE=mario82z28;3780477]posi is power to both wheels at the same time all the time limited slip changes power side to side NOT the same...[/QUOTE
Another IDIOT who has no business posting a reply if dosen't know what he is talking about.
First clue is the use of the so called word "posi".
Old Jun 5, 2008 | 10:14 AM
mario82z28's Avatar
uh go to hell, I'm no expert at rear ends just was going off of what i was told my bad if it was wrong
Old Jun 5, 2008 | 10:36 AM
DJP87Z28's Avatar
Well at least you admit it. Now you learned something, so now don't make the same mistake again.
Old Jun 5, 2008 | 10:58 AM
Guest
Guest
Posts: n/a
You'll have to adjust the suspension differently with a 'posi' as opposed to an 'open diff'. the posi will tighten up the car.
Other names for an open diff? Lets have some fun here-
One tire fire
one wheel peel
one rubber scrubber
feel free to continue this.....
Old Jun 5, 2008 | 06:02 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
But you stated incorrect information after a number of people had stated the facts.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
