Drop Spindles and ZR1 wheels...
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
I was wondering if anyone made drop spindles for the 86 Camaro, i cannot find any, anywhere i look? And Is it possible for the 17x11 ZR1 wheels to fit i n the rear with the 315/40(?)/17 tire and not do any mods? I m putting a 4th gen Rear so that will widen it a bit, but will it be enough? or will i need to get a mini tub kit?
Thanks for the info!
Never mind i found some for $550, does anyone make them cheaper?
Car: 1989 Camaro RS
Engine: 2.8l v6
Re: Drop Spindles and ZR1 wheels...
so can anyone tell me if i gotta get a mini tub kit to fit the 17x11 wheels with the 315/40r17 tires?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
no its been done many times.
it all depends on what offset you end up with, you may need a spacer, and some hammering on the front of the fenderwell will be required. Tubular control arms will gain you a little more clearance and you may have to clearance the bumpstop.
depending on ride height you may also need to roll the fender.
Car: 1989 Camaro RS
Engine: 2.8l v6
well they are stock zr1 wheels... but can i just cut out or remove the inside of the front wheel well... i figured the front zr1 wheels would fit... but if i need to could i just cut that inside piece out? it will be a stock ride height with the 2 inch drop up front...
Car: 86 Trans Am
you can cut anything you want, just be sure to weld a new piece back in when you are done.
