rear disc brake system questions.
Old Jun 15, 2008 | 11:03 PM
Simply-305's Avatar
Car: 1987 camaro RS/Z28 clone
Engine: 305 bored .030 over
Transmission: 700r4 slippin its way home
Axle/Gears: 9 bolt 3.43 gear
hi everyone.
i just installed a 9 bolt rear with disc brakes.
i originally had an open rear 10 bolt with drum brakes.
the rear suspension has hotchkis lower trailing arms and pan hard bar..
my question first off.
is that i have never seen a setup like this before.
on the driver side rear , the caliper faces the rear of the car...
on the passenger side the caliper faces the front of the car..
i have never seen this before so excuse my noobness.
if this is normal then my next question is.
when i replaced the brakes on this thing. i had no problem installing them on the driver side rear.
but when i got to the passenger side rear.
i was able to remove the top caliper bolt.
when i got to the bottom.
the bolt was too long and the head of the bolt hits my lower trailing arm.
i tried a million different ways to find a way to take the bolt out of its hole. but the head of the bolt was hitting the trailing arm.
i managed to sneak my pads into the caliper and my caliper over my rotors. but has anyone encountered an issue like this before??
any input is greatly appreciated.
thanks in advance
Old Jun 16, 2008 | 12:36 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: rear disc brake system questions.
That's normal for the cast iron caliper brakes, this way GM could use the same part number for both sides. I just finished replacing the passenger side axle shaft on my rear end this weekend. In order to remove the lower caliper bolt, the control arm needs to be disconnected from the rear and lowered out of the way, It might be a good idea to disconnect the e-brake cable also.
Old Jun 18, 2008 | 08:23 AM
OLDYELLR's Avatar
Car: '85 IROC
Believe me, the pass side caliper can be removed, although it looks impossible. On my old '83 someone had actually torched a hole through the LCA, but it's not necessary.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
novaderrik
Aug 10, 2015 12:44 PM
