Sway bar size
Old Jun 17, 2008 | 01:46 PM
draven1018's Avatar
Car: 1988 IROC-Z
Engine: 5.7
Transmission: 700 R4
Axle/Gears: Stock Borg Warner 2.77's
Sway bar size
Hi, I am brand new to this forum but I have had my car for about 8 years, and in that time I have learned some things & forgotten some other things. This is one of those things I have forgotten, I have an '88 IROC with the 5.7 I was wondering if someone could tell me what size my front sway bar is on it I want to order some poly bushings and end links for it and I dont know what to get. I think it is a 36 mm because I thought that was the size that came on the IROC but I am not sure and I haven't been able to find out thru internet research so I thought I would ask u guys since I am sure there are many more knowledgeable people on here than me, thanks in advance.
Old Jun 18, 2008 | 06:47 AM
91rss's Avatar
Car: 1991 Camaro RS
Engine: 3.1L
Axle/Gears: 10 bolt 3.23
Re: Sway bar size
if you got the 1le package then yes your front bar is 36mm and for bushings alot of members like spohn.net
Old Jun 18, 2008 | 09:54 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
Re: Sway bar size
You might also have a hollow 34 mm. That's what mine had. Not the 1le but an IROC w/ the FE2 or something like that. My rear was a 23 mm
Old Jun 19, 2008 | 06:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Sway bar size
I suggest you have the 34/24 combo. The 36/24 didn't arrive on Camaros until 89. The latter wasn't specific to 1LE cars. My 85 IROC was originally equipped with 34/24.
JamesC
Old Jun 19, 2008 | 03:26 PM
RacerX13's Avatar
Car: 88 Formula
Engine: LB9
Axle/Gears: 3.45
Re: Sway bar size
Probably a 34mm but you will need to measure it to be sure.
34mm=1.34"
36mm=1.42"
J-money
Jan 4, 2019 09:45 AM
camaro1185
Oct 26, 2015 06:51 AM
m00n420
Sep 11, 2015 02:39 PM
87camaro87
Sep 9, 2015 10:29 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
