TIRE SIZE HELP!
Old Jul 23, 2008 | 06:35 PM
LARKTIM's Avatar
Car: 1989 camaro
Engine: bad *** chevy
Transmission: a good one
TIRE SIZE HELP!
I have an 89 camaro that im building for street/strip, im wandering what the biggest tire is that i can put on there, i was wandering if some 50's would fit and if not what i would need to do to allow them.
Old Jul 24, 2008 | 10:50 AM
theMAGICALheat's Avatar
Car: 96 Souped up Firebird, 89 KITT
Re: TIRE SIZE HELP!
well, it depends on what you started with, 14 inch 15 inch rims? What is the recommended ORIGINAL tire size on that vehicle? (check the sticker on your driver door for tire specs ) my 89 pont. firebird formula has 16" wheels and that takes 245/50/16. 245 is how wide,the 50 is how 'tall' the tire is (50 is in the low profile range). 50 is aspect ratio. If you can find someone with the Plus Size Tire Guide (with RED PAGES) That is the best one to look at. It will show you what you can go up to. Usually, if you have 14"s, you can go as far as Plus 2 (to 16). If you go any lower than a 50 series tire, you have less rubber between the rim and the road and will have not as nice of a ride usually. Hope that helps?
Old Jul 24, 2008 | 08:03 PM
Tru2Chevy's Avatar
Car: 1987 Camaro
Engine: 400 sbc
Re: TIRE SIZE HELP!
What's your original tire and wheel size, and what size wheel are you thinking about going with?
Are you planning on just one set of tires for both street and stip duty?
- Justin
Old Jul 25, 2008 | 08:05 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: TIRE SIZE HELP!
Need more info...what size rim do you want to run.
If you're talking 15" you can run a 15 x 8 with 275 50's
You can also run a 15 x 10" with 295 50.
Old Sep 16, 2008 | 10:10 PM
Wrenchead84's Avatar
Car: 89 Camaro RS
Engine: 5.0 TBI
Axle/Gears: ???? want 4.10's
Re: TIRE SIZE HELP!
yea right 295/50 in the front?
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
