Rough Suspension
Old Jul 24, 2008 | 11:38 PM
Nugget2109's Avatar
Rough Suspension
My 92 camaro has a really rough suspension.
It is all stock, but it hits hard over rouch roads, and seems to be really loose, because when i go over a rough bump, it just bounces up like 3 times and most likely scrapes the front end. what can i do to upgrade to a better suspension? springs? strut?
Old Jul 24, 2008 | 11:56 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Re: Rough Suspension
The bouncing sounds like you def. need shock/struts. As for brand its your choice. I would stay away from the Monroe and Garbrial if you do any kind of performance driving. KYB makes decent parts at a good value. After that it goes up in cost drasticly. Tokico's and Koni's will cost you $$$$$, but they are top quality.
Search a bit, you may find what your looking for.
Max,
Old Jul 25, 2008 | 12:10 AM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Old Jul 25, 2008 | 12:11 AM
theMAGICALheat's Avatar
Car: 96 Souped up Firebird, 89 KITT
ok, you NEED to take your car to a reputable shop and get yourself the steering/suspension evaluation. I know that Sears auto centers used to do a free inspection.
Monroe over the last year or 2 has started making a QUICK STRUT which is the strut, the strut mount and the spring. its a whole assembly. I can't remember but don't these cars have front struts/rear shocks?? Will have to investigate.
your control arm bushings and sway bar bushings are most likely bad, check your tires: do they look like they are worn on the inside or outside? may need tie rods and ball joints. Just had to do 1400 dollars worth of susp. work on my 89 pont. firebird formula (less struts/shocks) and it was 90 percent suspension work. May need center link too if your steering is loose (may need steering nuckle too)
Old Jul 25, 2008 | 12:17 AM
Car: Camaro RS
yup
Old Jul 25, 2008 | 12:33 AM
myvmax1's Avatar
Car: 91RS, 91RS
[QUOTE=theMAGICALheat;3834840Just had to do 1400 dollars worth of susp. work on my 89 pont. firebird formula (less struts/shocks) and it was 90 percent suspension work.[/QUOTE]
Where did you manage to spend that much money? I'm not saying you didnt, I'm just wondering if you back half'd and put a 4-link in. LOL
LT1Formula
Oct 8, 2015 08:34 PM
Jlanz55
Sep 29, 2015 08:55 AM
