Tire Question
Old Aug 24, 2008 | 10:59 AM
JesterHead1651's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.0
Axle/Gears: stock
Tire Question
Hey guys, I know this has probably been asked alot but I cant seem to get a straight answer.
I currently have 245/50/16's on my 89 iroc all around (Iroc Rims)
I want the tires to be WIDER on the rear so I discovered that 255/50/16's would be a feasible tire choice. Now should I do 255's all around, or will that be to wide for the front end? Maybe 245's on front 255's on rear? Is that a better choice? Also will I have any clearance problems?
Old Aug 24, 2008 | 08:56 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: Tire Question
I've never had that wide of a tire on the front, but there shouldn't be any problem fitting the 255/50/15 all around as it really isn't that much different of a size. They will be about 1/2" wider and taller than the 245/50/16.
Old Aug 24, 2008 | 10:09 PM
Engine: 5.0
Axle/Gears: stock
Re: Tire Question
thanks man im glad i finally got a good answer. im think im goin order four 255s soon. should be sweet!
Old Aug 25, 2008 | 11:41 AM
Engine: 5.0
Axle/Gears: stock
Re: Tire Question
wait a tik you said on a 15 inch rim, im putting it on a 16
Old Aug 25, 2008 | 11:58 AM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Re: Tire Question
I've got 245s front and 255s rear (16). My fronts have the same backspace as the rear (aftermarket Centerlines). With the 3rd gen disc brakes on the front, the tires hit at full lock.
No problems with the back.
Old Aug 25, 2008 | 12:20 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Re: Tire Question
Typo, I meant with a 16" wheel.
Old Aug 25, 2008 | 04:55 PM
Engine: 5.0
Axle/Gears: stock
Re: Tire Question
alright cool, but would you recomend 245s up front and 55s on the rear?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
