Rear end code..not in the book?
Old Sep 7, 2008 | 02:16 PM
wardce's Avatar
I am pulling parts from my donor car to put on my v6-v8 swap project. The donor car is a 1986 IROC-Z (its a P.O.S. don't worry). I got the numbers from the rear end and they read 6HS C160 L (the code is very clear). I have checked the books and I have not found anything that matches. Can anyone help? The car does have rear disk brakes and I was wanting to put it on the good car. I don't want to pull both rear ends unless it would be worth it. Any help would be appreciated. Thanks...
Old Sep 7, 2008 | 09:59 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Rear end code..not in the book?
There are 6Hx codes for 88/89 axles but not 6HS. What kind of disk brakes are on it? Steel or aluminum calipers? Maybe it's a 90-92 diff that someone swapped in.
C160 L
C = Buffalo assembly
160 = Day of year
L is probably an E which means posi or it's a 1 meaning day shift.
When in doubt, pull the cover and look inside.
Old Sep 7, 2008 | 10:15 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I'm not sure what the codes mean, but if the rear in the IROC-Z has the disk brakes and you want them, why not just swap rear ends. It's probably the easiest way to make the swap. Then again, you haven't mentioned anything about which rear ends have a posi or what gear ratios are in each. Are they both 10-bolts, both 9-bolts, or is one a 10-bolt and the other a 9-bolt. If you have one 10 and one 9, your going to need different backing plates for the brakes to be swapped.
Mike
If your not sure...
G80 = posi
To know what gear ratio is in the car (or what came stock), post up the RPO codes. The codes concerning gear ratio will start with the letter G.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
