V6 coils on V8 car for lowering?
Old Sep 9, 2008 | 10:29 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
>anybody try coils from a v-6 car on a car with v8 motor? I swapped out my A/C, iron heads for alum., and put in a T-5 in place of the auto...the car sits 1" higher than stock.....I was wondering if I could put in V6 coils and what would happen to: A) ride height; B) handling/spring rate/comfort? Anybody try this?
Old Sep 14, 2008 | 12:45 PM
Camaro5690's Avatar
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Re: V6 coils on V8 car for lowering?
I think that would be a bad idea, V6 springs have a much lower spring rate. So you would be sacrificing alot of handling to lower it. Best option I have seen is cutting Moogs to lower.
Old Sep 14, 2008 | 01:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Spring rate is too soft. I ran V6 coils on my BBC car for a few years. Although they worked because the front of my car was so much lighter, they didn't perform as good as a proper set of springs.
RedLeader289
May 28, 2019 01:47 PM
RedLeader289
Sep 23, 2015 06:50 AM
jbates346
Sep 22, 2015 05:22 AM
Nick McCardle
Sep 10, 2015 08:36 PM
