NEW! Replacement Poly Ends for Rod Ends
Hello Members,
UMI Performance has developed and manufactured adjustable ends to convert rod ends to polyurethane bushings. These items are designed to replace 3/4-16 threaded rod ends used on panhard bars and control arms for the 1982-2002 F-Body. They work excellent to replace worn out rod ends or inexpensive rod ends making unbearable noise. They are priced at $29.99 each and available in red or black. Below is a link for additional information, if you have any questions please ask.
Thank you!
Ryan
http://www.umiperformance.com/produc...ategory_id=170
Thank you!
Ryan
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
Re: NEW! Replacement Poly Ends for Rod Ends
will these work with adjustable torque arms? I cant stand the rod end on mine. to much noise. if not, do you make one for torque arms?
Car: 1992 RS
Engine: 01' LS1
Im talking about the front mounted rod end I meant to say that. I have a spohn torque arm, they give you a option of a rod end or a poly end. im not sure if yours are similar. I dont think spohn makes one, im hoping you do.
I am unsure on the width Spohn uses on there torque arm mounts.
If you go to there site they do sell just the mount under replacement parts.. it looks very similar and priced around the same too.
Hope that helps!
Ryan
Hope that helps!
Ryan
NBrehm
Aug 5, 2015 07:57 PM
