Coilover kit and camber plates
Old Nov 7, 2008 | 05:44 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
I'm about to buy Koni Yellow and Spohn or BMR coilover kit, but i was wondering if i can use J&M tubular adjustable camber plates instead of Spohn or BMR upper strut mounts to get even bigger adjustment on suspension, will they fit??
best regards
Old Nov 7, 2008 | 04:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Coilover kit and camber plates
No
the issue i found is that the coil spring itself sits up into the mount, and the hole in the strut tower is only so large. All the extra adjustment of the camber plate would not benefit you much because the spring would hit the sheet metal of the strut tower before you got any where near the limits of the adjustable camber plate.
Ground control weight jacks are a good alternative, and probably what i should have gone with. I may still go with them.
Old Nov 7, 2008 | 06:07 PM
WASyL's Avatar
ok and what are those weight jacks ?? can you show me any pics because i couldn't find any picture and as i'm from poland sometime it is hard for me to find things
best regards
Old Nov 7, 2008 | 07:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
they look just like the threaded sleave adjusters that come with the coil over kits, but they are for ~5" springs, so they are much larger, and they sit in the a-arm, and using a more conventional ~5" coil spring.
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
