Post pics of your NHRA legal 5-point harness install
Old Nov 23, 2008 | 03:25 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
....That still retains the factory seatbelt. I did search but most just toss the factory belt.
I took out my factory seatbelt and used those mounting points for the 5pt's lap belt.
I'm looking for some ideas on how to mount the lap belt for the 5-point harness while still retaining the factory seatbelt for street use.
Here are some pics of my bar install which I did myself. It still needs to be painted.
Old Nov 27, 2008 | 06:20 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: Post pics of your NHRA legal 5-point harness install
what is on the drivers side door bar? looks like a piece of pipe over a piece of pipe?
Old Nov 27, 2008 | 06:44 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Looks like a swing out side bar
Old Nov 28, 2008 | 09:04 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Old Nov 28, 2008 | 09:07 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
why don't you just use 5-point while car street use, is it illegal in States ??
Old Nov 29, 2008 | 03:29 PM
It's not DOT approved so it probably is illegal although I don't think most officers would care. Even with the RCI Cam-lock harness its a pain in the *** and it's pretty hard to shoulder check too.
Thanks for the pics. Looked like it's mounted to the factory locations like mine is.
Stage20; It's a Competition engineering swing-out kit.
Old Nov 29, 2008 | 03:41 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I got the only DOT approved harness available. Schroth Ralleye 3 harness. DOT approved and i mounted it in the stock location using those stock bolt holes. rear piece goes over the bar down to the rear seats old seatbelt area.
Should be legal but then again i'm not sure. State law here says of factory type is legal. mine is still a 3 point like factory using factory locations and has DOT approval so they should be fine.
I'll let you know when i get pulled over
Old Nov 29, 2008 | 03:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I got the only DOT approved harness available. Schroth Ralleye 3 harness.[/URL]
It's not NHRA approved though.
Old Nov 30, 2008 | 11:48 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
edit:
i see that NHRA requires
Quick release 5 point 3 inch harness SFI Spec 16.1 mandatory in cars that are required to have a roll bar or roll cage
dammit, my car still isnt legal. But then again there are many guys using regular stock selt belts in their cars that need roll bars so whats the deal? My seat belts are designed to be like OEM spec while still giving you a harness. But its 3 point and not a 5, just like OEM seat belts. So seems like the rule is cloudy to me.
Oh well its a street car anyway
Old Nov 30, 2008 | 04:23 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The rule is perfectly clear, but enforcement may vary at individual tracks for non-NHRA events.
Old Dec 1, 2008 | 02:02 AM
WASyL's Avatar
ap
edit:
so get DOT and FIA approved and You will be legal both street and racing
Vintageracer
Jan 10, 2020 05:33 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
z28addict8490
Aug 7, 2015 08:48 PM
