Newer Style Camaro wheels fit?
Car: 1989 IROC
What needs to be done to make the newer style 16x8 Camaro rims fit a stock 1989 Camaro with disk brakes?
Car: 1990
Axle/Gears: stock
Re: Newer Style Camaro wheels fit?
the stock disk breaks will not be a problem. you will need adapters and you can get the from jeggs or summit. if they are not stock disk breaks you will have to see if they are big enough, so get our your tape ans start taking measurements. why not look on the rims board and do a search and you might find more information. and look on the parts for sale board too and you should find them, they are always for sale.
Car: 2001 Jeep 1984 S-10 daliy drivers
Engine: 1983 has a 305 1984 Trans Am
Transmission: 1983 has 350 tubo 1984 Trans Am
Axle/Gears: stock
I have a set of 16 in wheels from a 02 camaro. What do i need to do to make them fit on a 83 camaro if they will. It hits the tie rod end on the front. dont know about the rear. Front is disk and rear is dum. thansk for any help.
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
I think you just need some wheel adapter, 2" is the usual mentioned. The bolt pattern is the same.
Skulte is the sure/$$ way.... ebay is $ (cheaper, but no brick store behind them).
kah992
Aug 19, 2015 02:55 PM
