Rear End Trouble '91 RS
Old Jan 28, 2009 | 04:35 PM
stevo42's Avatar
I have a 1991 Camero RS and the rear end is messed up you can lean on the side and the rear end will shift almost 2 inches it just wobbles back and forth... especially scary going over 50 and it feels like im hauling a single axle trailer
if anyone has an idea as to what this could be it would be greatly appreciated
--Stevo
Old Jan 28, 2009 | 07:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Rear End Trouble '91 RS
Look under it to see if anything is falling off or broken. Sounds like the panhard bar isn't working.
Old Jan 29, 2009 | 07:28 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
ck. your panhard bar/trac bar brace . above rear axle , drivers side of body to pass. side of rear axle . i had all 3 bolts to the body on my first 3rd. gen. just fall out . if this is your case ( sure sounds like it ) be sure to use locktite on replacement bolts . good luck .
Old Jan 29, 2009 | 03:31 PM
stevo42's Avatar
Thank you both so much, im by no means a car guy so i was thinking it was somthing along the lines of bad suspension lol..
thanks again.
--Stevo
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
