Too much freeplay in steering?
Old Jan 31, 2009 | 09:30 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Wondering if there was a way to tighten up the steering a bit. I have to move the wheel 2-3 inches either direction to move the car. The power steering fluid is full, and the steering wheel is mounted properly.
Old Jan 31, 2009 | 10:19 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Re: Too much freeplay in steering?
You need to check out the front end componets first to see what is worn.
Old Feb 2, 2009 | 08:15 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Could be ball joints, tie rod ends, slop in the steering box, etc. I'd get under there and see what needs to be replaced. Almost all these cars have sloppy steering and need some work.
Old Feb 10, 2009 | 08:40 AM
frbdgirl92's Avatar
I have the same problem. I replaced my front struts, ball joints, wheel seals, and idler arm. I don't know where the steering box is or what I'd need to do to fix it. I have a '92 formula.
Old Feb 10, 2009 | 11:40 AM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
A common problem with third gens is, the center drag link. It is the component that transmits the left-right movement between the front wheels.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
