tires
Old Feb 22, 2009 | 09:07 PM
bonddav's Avatar
tires
what are the largest tire i can put on the 16" stock rim of a 91 camaro i have 245/50-16zr now had what is the best tire its hard to find that size in a tire that i like.
Old Feb 22, 2009 | 09:20 PM
Stippy17's Avatar
Car: 1986 Trans Am, 1985 Trans Am
Engine: 400 SBC, H.O. 305
Transmission: TH400, 700R4
Axle/Gears: 10 Bolt/3.73s, 10 Bolt/3.73s
Re: tires
I think a BF Goodrich 245/50/16 would be a nice size tire. I have BF Goodrich 295/50/15s on my stock set of 15s, and I like them alot.
Old Feb 22, 2009 | 09:39 PM
Stephen's Avatar
Car: 87 GTA
Re: tires
Does nobody before posting & asking? This SAME question is asked every month.....A simple will give you the answer your looking for. without adding to the posts on TGO.
It gets old answering the same questions over & over, but ignoring a question seems rude. Maybe this response seems rude too, but it is simply direct & clear.
Old Feb 23, 2009 | 01:58 AM
rhit_rs's Avatar
Re: tires
If your wheels are stock, they're 16"x8". Go to tire rack (www.tirerack.com) and see which tires will fit your 8" wide wheels. On the specs page for each tire they have the range for recommended wheel width. You probably can't go larger than 255 wide, depending on the series (40,45,50,etc). Also, keep an eye on the overall diameter because if you change that much from stock, your speedometer will be off a little.
Old Feb 23, 2009 | 06:12 PM
bonddav's Avatar
Re: tires
the bfg in my size i did not like the tred like the 17" because they don't seam to have a wide contact patch like my nitto's
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
