Need new springs
Old Mar 4, 2009 | 03:48 PM
ckyfreak2010's Avatar
Need new springs
hey i have a 92 rs v6, i have a feeling a i need new springs, but i do not want to lower my ride height, i would also like to make them stiffer so i could carry more weight in my car, because i drive to school daily with 4 friends, so does anyone out there know where i can get stock ride neight springs that may possibly be stiffer.
Old Mar 5, 2009 | 06:27 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Need new springs
fronts= moog 5660/5662/5664. all are for V8 powered 3rd gens. they will be alot stiffer than ur stockers. go with the 5660 they are 598lbin rate. your V6 springs are something like 375-400lb in.
5660=598lbin rate stock height
5662=704lbin rate stock height
5664=748lbin rate stock height
the rears all are the same i believe... well for the V8s they are. that would be the moog 5665s =107lbin rate stock height.
Old Mar 5, 2009 | 07:24 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Replacing the fronts would help, but most of the weight from the passenger compartment seems to be carried in the rear (at least when I have passengers in my car). Stiffer rear rates would help the most, in my opinion. You might want to look getting new shocks/struts. Their ressistance to compression would help aid the springs. The only way you could get stiffer than stock rear springs and stay at factory height would be to order some stiffer, but slightly shorter than stock (stiffer so the weight of passengers won't compress the springs as far and shorter because if you just increase the rate with the same uncompressed height, it'll jack up the rear of the car).
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
