a small dilema!!
Old Mar 4, 2009 | 11:42 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
a small dilema!!
im in the process of rebuilding the front suspension and steering components on my 82 sc street/strip car. the engine (355) and tranny (t56) are out. i installed the following new parts: balljoints, ES control arm bushings, monroe gasmatic struts, inner and outer tie rods, center link, idler arm, and adjusting sleeves. i sandblasted and powdercoated the k member, control arms and springs with 1 coil cut off. my problem is im going to get the car painted in a week, i took the upper strut mounts off to sandblast and paint them. i got the alignment somewhat close, so i can roll it on a trailer and take it to the painter, is there any way to get my caster camber somewhat close to being correct when i put the engine and tranny in, i dont want to get it painted with the upper strut mounts on and then go get it aligned and they move the plates and you can see the primer underneith. i want to avoid taking the plates back off. any suggestions are greatly appreciated
Old Mar 5, 2009 | 09:59 AM
Guest
Guest
Posts: n/a
Re: a small dilema!!
Take reference measurements from two angles on each and write them down. Measure from the top strut shaft to the fender/hood seam, and lets say another one from a point on the firewall. When you reinstall them, you put them right back to those tragulated distances.
Old Mar 5, 2009 | 06:09 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
What about putting some spacers between upper strut mount and inner fender? You are getting it painted without the engine, right? Might have to use some longer bolts and washers instead of the C-stud bracket. 3/8-1/2" gap should get some paint under the plate. Course they're still going to scratch it during the alignment.
NZKnight
Oct 15, 2015 02:47 PM
skinny z
Oct 5, 2015 06:23 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
