lock lug nuts
Old Mar 11, 2009 | 12:17 PM
cc305's Avatar
Car: '92 camaro rs
Engine: 305 tbi
lock lug nuts
situation: back two tires have lock lug nuts on them. one per tire. i bought the car from someone else and called them and they lost the key to get them off. i have nothing around here to bust them off. i searched the parts store and they have nothing. i need some help. i ave to adjust the rear brakes and change the suspension.
Old Mar 11, 2009 | 12:19 PM
dsull357's Avatar
Car: 92 Camaro RS
Engine: 3.1
Re: lock lug nuts
You could try some of the tire stores. I had the same problem but was able to find the key hidden in the car. But I check some of the tire stores and they said if I bring the car to them they might be able to get it off for me. Just an idea.
Dsully
Old Mar 11, 2009 | 12:20 PM
cc305's Avatar
Car: '92 camaro rs
Engine: 305 tbi
Re: lock lug nuts
pls. disregard. i just did a search on here and found a good idea. i can weld a nut on and get it.
Old Mar 11, 2009 | 01:37 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: lock lug nuts
Another trick is to find a socket that's just barely too small to slip over it, and hammer it on.
Old Mar 11, 2009 | 08:16 PM
84olmpcboy's Avatar
Car: 84 olympic edition camaro
Engine: 2.8
Re: lock lug nuts
If you don't want to weld the nuts on just get a set of vice grips and put them on REALLY tight. This is what I did to mine and it worked fine.
kkirch15
Sep 30, 2015 04:44 PM
gord327
Sep 29, 2015 10:18 PM
3.8TransAM
Sep 27, 2015 08:37 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
