Welding in new floorpans, question about frame
Old Mar 24, 2009 | 01:16 PM
_87GTA_'s Avatar
I was always a 2nd Gen guy, you know, a massive steel frame under the car. However, I noticed the frame on my 3rd Gent GTA is kinda meshed into the floor-pan. We need to replace the current floor-pans due to rust-through. Are there any special procedures since the frame is different? Or do we simply weld-in..........
Old Mar 24, 2009 | 01:21 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Welding in new floorpans, question about frame
First drill out all the spot-welds so you can leave the stamped-sheetmetal subframe in place. Dunno what pans you bought, but it's best to finish either the right or left half before starting on the other. Even better would be welding in subframe connectors before starting on the pans.
Old Mar 24, 2009 | 07:09 PM
eschevyrda's Avatar
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
why would it be better to weld the sfc before tackling the floorpan?
Old Mar 30, 2009 | 03:27 PM
Guest
Guest
Posts: n/a
Just to add some strength to the body before you cut out a major portion of its structure. Do that or remove as much weight as possible and/or brace/rack the frame so the body does not bend. I know of people that just cut+weld, but ideally it would be best not to rely on the floppy thirdgen chassis to retain its shape with the floor missing.
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
