Strut Brace?
Old Mar 30, 2009 | 07:27 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Strut Brace?
I'm looking to buy a strut brace for my engine bay, but i have a tbi with a 14" air cleaner on. Anyone know of a strut brace that works around this and could use stock bolting pattern?
regards,
Timinsk
Old Mar 30, 2009 | 08:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Strut Brace?
None that I'm aware of that will fit your car. IIRC, MAC makes one for the TPI. As you probably know, the Edelbrock will fit if you're willing to drill some holes.
JamesC
Old Mar 30, 2009 | 09:39 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Strut Brace?
ouch... drilling.. Theres no like plates i could apply to retro fit or something?
Old Mar 30, 2009 | 10:31 AM
JamesC's Avatar
Re: Strut Brace?
I'm unaware of anything. Here's link that may dispel some of your apprehension about drilling:
https://www.thirdgen.org/forums/susp...-3-pt-stb.html
JamesC
Old Mar 30, 2009 | 01:58 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Strut Brace?
aaww nothing for stock struts.. darn, i'd like something like that but for stock... darn, i have the same air cleaner too... kind of lol open air though
Old Mar 30, 2009 | 02:04 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: Strut Brace?
Keep in mind that unless you have solid bearing strut mounts, a STB is basiclly pointless.
Old Mar 30, 2009 | 02:24 PM
Stephen's Avatar
Car: 87 GTA
Re: Strut Brace?
That's a matter of opinion.
I've done STBs before, with stock strut mounts & a STB did still make a noticeable difference.
Old Mar 30, 2009 | 03:25 PM
JamesC's Avatar
Re: Strut Brace?
JamesC
Old Mar 30, 2009 | 04:24 PM
krisb410's Avatar
Re: Strut Brace?
I'm sorry I'll have to disagree with you. Despite what you consider a "noticeable difference"
The rubber in stock type mounts will allow way more flexing then a solid bearing. So even with an STB, the stock rubber will flex. And I'm pretty sure the rubber will flex before strut towers. It's just stupid to spend money on a STB and still have rubber stock type mounts. What would make more sense, is buy solid mounts 1st, then get a STB.
Think of it like this. I think we all agree that SFCs should be the 1st thing you do, right? And why is that? Basicly it's the same theory to solid mounts and a STB.
Old Mar 30, 2009 | 04:31 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Strut Brace?
There is a lot of deflection in the strut towers - just the way GM built the cars in a cheap a$$ way. Tying them together is not so great, a 3 point anchored into the firewall is ideal.
I noticed a huge difference in front end stiffness by putting an Edelbrock 3pt STB on my Camaro - I don't have aftermarket strut mounts.
Old Mar 30, 2009 | 04:35 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Re: Strut Brace?
Ask around, I think someone on here fabricated their own and it turned out nice.
Old Mar 30, 2009 | 04:45 PM
krisb410's Avatar
Re: Strut Brace?
Well, when you get some, then you'll see what I mean.
Old Mar 31, 2009 | 04:37 AM
1988-305-tbi's Avatar
Re: Strut Brace?
within one week i installed both the J&M caster/camber plates and Edelbrock 3 pt. strut tower brace, when compressing the front suspension the stock strut tower mounts would allow 1/4-1/2" of flex up and down, and a fair amount of slop from side to side.
first i did the solid strut mounts, then the brace. I would say that 70% of the improvemnet came from the solid strut mounts and 30% from the strut tower brace, the brace did make the front feel tighter and more responsive, but the biggest improvment was from the solid mounts
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
