Suspension
Old Mar 31, 2009 | 07:49 PM
84TransAm383's Avatar
Suspension
So i just put on my spohn torque arm and crossmember and must move my exhaust. It is already 3 inches id but sat low and now must be lower. What can i do to get some more ground clearance for the car. The torque arm can adjust the rear a little bit higher but im still 2 maybe three inches off the ground
Old Mar 31, 2009 | 08:13 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Suspension
how is you exhaust routed? stock style? duals? pics?
Old Mar 31, 2009 | 08:53 PM
Re: Suspension
its got long tubes so it comes down under the crossmember becuase how far the headers go. it then connects to a y pipe single down to the right of the drive shaft and straight back because i have sfc that took the stock location. ill get pics tomoro
Old Mar 31, 2009 | 09:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Suspension
you have to do a custom crossmember, the crossmember mounted torque arms are not LT friendly, unless youcan reroute the tubes around the crossmember
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
