Steering shaft???
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Steering shaft???
Has anyone replace the whole assembly between the steering box, and the steering shaft???? If so where besides the dealer can you get the part??? My rag joint is shot.......Thanks.....
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: Steering shaft???
This is the only complete piece I've ever coem across. I have no idea on the quality, but I'm guessing it's Chinese.
http://cgi.ebay.com/ebaymotors/Camar...1%7C240%3A1318
Car: 89 RS, 92 Z28
I have a couple of the rag joints already, but there is a flexible union at the top, and the rubber boot is tore up....Not sure how important that is, but I am doing the "Shotgun" aproach to the front end...If it is there, replace it...LOL.....Thanks for the replys guys...
Car: check
Engine: check
Transmission: check
Also do a search for a thread on "astro van shaft." If you can do some mild fabbing this is another alternative that is better then a replacement OEM set up.
RBob.
RBob.
Car: 1985 Iroc, t-top
Engine: 5.0L HO L69
Transmission: Mt 5 speed
Axle/Gears: 3.73 Non Posi, Alum Drums
I bought the one off ebay, works great. The box said made in Australia. Based of the quality it maybe a Holden part (GM Australia), or a really nice asian part. I was impressed. I believe they sell the exact same one at Yearone for more $.
Car: check
Engine: check
Transmission: check
Oh no, not again. Cut me a break. A properly set up Astro Van shaft has a collapsing slip joint. Just like the OEM one in our f-body's.
See, if you have ever LOOKED at an Astro Van shaft, THEY HAVE A SLIP JOINT. AND, THIS SLIP JOINT IS USED WHEN MODIFIED FOR AN F-BODY.
RBob.
RBob.
You can use whatever you like. I've seen some pretty unusual Astro Van set ups here that I would never put on my car. Notice you use the phrase "Properly set up." Thats not always the case in my opinion.
Car: check
Engine: check
Transmission: check
Rather rude of you to assssuuuume that I was one of those that did hack jobs...
RBob.
RBob.
RBob.
RBob.
RBob.
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
