Best way to raise the rear?
Car: 1986 Z28 Camaro
Engine: Rebuilt 82' 305
Axle/Gears: Non-Posi stock =(
Hey, just curious. I have always wanted to raise the rear end of my car up just a bit. an inch or two....I know people say air bags arnt good for third gens... how else could I do it fairly easily?
-Andrew
-Andrew
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Best way to raise the rear?
depending on the condition of the origional springs, a new set would most likely raise the rear a bit. Moogs iroc replacement springs raised my car about 2" when i put them on a few years back
and the rear springs are easy to change
yea, I have heard that. But when refering to 1-2 inches higher, i was thinking from stock hight
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
86 is right. Swap in the Moog replacements and keep the insulators and you'll jack the car up significantly.
JamesC
JamesC
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
gas shocks, my rear end lifted a little when i put them in. I put in Gabriel Ultras.maybe something to do with the spring insulators would be a good way to increase ride hight.
toronto formula
Nov 10, 2015 06:17 AM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
