strut tower brace
Old Apr 12, 2009 | 04:23 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
strut tower brace
I have been reading over some older posts and have not found the answer I have been looking for. So would I notice any difference by having one or not?
Old Apr 12, 2009 | 05:52 PM
the zander's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
Re: strut tower brace
The function of a strut tower brace is to control the deflection of the strut mounts under cornering loads. This reduces bump steer and typically allows high cornering speeds due to reduced camber loss and body flex. It probably also reduces the amount our unibody car creak (due to flexing).
Really though, i would be skeptical if you would notice any improvement on a stock '88 vehicle without some supporting upgrades. ie. poly or delrin control arm bushings, upgraded springs/shocks, and perhapses some more aggressive rubber.
if you happen to have some of the above mods, then it would be a worthwhile upgrade.
-Z
Old Apr 12, 2009 | 06:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
like said above, if your bushing are in good shape and not deflecting like mad, you will notice a difference
Old Apr 12, 2009 | 07:05 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I KNOW i felt a difference. Wheather it be the placebo effect from spending $150, i know it helped.
Old Apr 12, 2009 | 07:37 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by the zander
...without some supporting upgrades. ie. poly or delrin control arm bushings, upgraded springs/shocks, and perhapses some more aggressive rubber.
I'd add spherical upper strut mounts.
JamesC
Old Apr 13, 2009 | 09:54 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
i dont think it was a placebo effect, i noticed a big differance and spent nothing. hmmm maybe i just wanted it too feel better... nah
Old Apr 13, 2009 | 03:54 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
I noticed a BIG difference in fast sweepers..... not many in daily driving, but they are there; from slightly scary to solid.
Blew my mind to realize that was flex.
Old Apr 16, 2009 | 07:39 AM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
I noticed it on mine! between STB, Wonderbar and SFC my car rode totally different -had I known, I would of done it years ago
Old Apr 16, 2009 | 07:56 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
those pictures should give you all the info to decide if is it woth to buy strut tower brace (and even other parts)
STB before
after:
in corners before:
after
best regards
Old Apr 16, 2009 | 07:57 AM
WASyL's Avatar
part 2
Fender bar
before
after
SFC before
after
WASyL's Avatar
part 3
Stablilizator (anti-roll bar = sway bar)
before
after
best regards
Old Apr 16, 2009 | 07:59 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
STB before
after:
in corners before:
after
best regards
Very nice posting of animations!
Seriously, even though they are exaggerated, everyone can see what an STB means to accomplish. Of course a 3 point offers more rigidity by tying the firewall into the strut towers.
Old Apr 16, 2009 | 08:38 AM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
Me personally i noticed a difference. But then again i did a bunch of upgrades at once. so it was a MAJOR change in handleing. I installed a BMR 3 point brace. as well as eibach springs panhard rod LCA's new shocks,struts, as well as all new front end parts. Car rides VERY stiff and definatley sticks to the corners at 70 plus MPH.
Old Apr 16, 2009 | 08:57 AM
Flip 2's Avatar
Engine: C5 LS1
STB by ITSELF will help a lot.
Adding the other stuff mentioned, one at a time, or all at once, just makes things better.
STB first, then add on. A smile at every step!
Old Apr 16, 2009 | 10:30 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I guess I should do the testing I was thinking about doing. I was going to test lateral g limits with my edelbrock bar as a 2pt, as a 3pt, and with it off. Anyone interested, or shouldn't I bother? Ive just got to find a big parking lot that is as flat as a pancake... Maybe I can after an autocross event.
Old Apr 16, 2009 | 10:47 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Dooooeet. I need to see if I should spend the money on one or not. lol. At least now I know the TBI one will clear an LS2
Old Apr 16, 2009 | 11:34 AM
Stephen's Avatar
Car: 87 GTA
I swapped out my Edelbrock 3-pt for a UMI 2-pt. I noticed ZERO loss in handling.
The Edelbrock piece was thin wall tubing vs the ticker wall tubing of the UMI. While I agree that a 3-pt SHOULD be stronger & noticeable, I think that short of a purpose built track car, you'll never notice any difference. Visually? I do sorta wish the UMI one was a 3-pt.
BTW....I got the UMI one for FREE, so it wasn't my wallet trying to justify the cost, by thinking it was just as strong. Had there been a loss, I woulda just put my Edelbrock one right back on.
Old Apr 16, 2009 | 12:28 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
UMI needs to make one for TBI...hint, hint
Old Apr 17, 2009 | 03:39 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Stephen, I noticed you used or are using BOTH of the STB's I have been contemplating on getting.
They cleared your L98 fine right? Do you think they would give me a problem since I am using SLP runners?
Old Apr 21, 2009 | 01:03 PM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
Stephen, is the UMI STB bolt-in? No drilling required in the towers? It says on their site it won't fit with aftermatket intake runners, is your L98 runners/intake stock? I tried to check with UMI on if their STB would fit with my SLP runners and TPiS base, but they were not sure it would fit.
Old Apr 21, 2009 | 01:22 PM
Stephen's Avatar
Car: 87 GTA
There are 2 PURELY OPTIONAL holes in the mounting b rackets for 2 more bolts to go in, but you would hafta drill holes for those 2 bolts, in the strut towers.
I still haven't bothered to put those 2 optional bolts in. So yea....STRAIGHT BOLT-IN.
I do have stock runners, base & plenum. Do yours set up higher than a stock TPI assembly?
Old Apr 21, 2009 | 03:29 PM
Car: 1987 IROC-Z
Transmission: TH350
What about poly motor mounts... I heard they raise the motor a little. Would that cause the UMI STB to not fit. I have the Edelbrock STB but I am just curious.
Mike
PS - I didn't have time to get the bar on my car before the autocross on Sunday so I'll try for the next on. That and it was raining so there were puddles everywhere.
Old Apr 21, 2009 | 10:23 PM
usamuscle892's Avatar
Car: 1992 Z03 RS
Engine: (L03) 305TBI
Transmission: TH-700R4
Axle/Gears: bone stock
so basically is edelbrock the only supplier for TBI STB's?
Old Apr 25, 2009 | 10:05 AM
dancinhans's Avatar
Did you have any clearance issues with the wonderbar around the fan mounts and steering coolant lines?
Old Apr 25, 2009 | 11:39 AM
Stephen's Avatar
Car: 87 GTA
The Wonder Bar is a stock piece, so no....No mods needing to bolt it n.
Now an aftermarket one? Maybe. I dunno. Mine is a factory one.
Old Apr 25, 2009 | 03:46 PM
JamesC's Avatar
After market here, a Global West piece. No problems with fitment. That said, some members have reported interference with after market versions. A search might provide the name of a manufacturer.
Old Apr 25, 2009 | 04:12 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
which brace would clear the mini ram?
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
