refinishing rims
Old Apr 15, 2009 | 04:02 PM
kowalzekc's Avatar
refinishing rims
I am refinishing a set of 4th gen 5 spoke rims. I am totally striping the current paint off and repainting them myself. I am going with a high heat resistant paint and I was planning on doing several coats. Has anyone done anything along these lines before??? Any tips?
Old Apr 15, 2009 | 04:08 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: refinishing rims
I did on a set of '86 iroc wheel....I polished out part of the spokes and the rest I painted black to match the car color. I sanded it down good...cleaned it of course...the I used I believe a high temp primer (1 layer), a high temp color (black on mine)2-3 layers, and then a high temp clear coat (2-3 layers)....I used the caliper spray paint that you should be able to get at a local parts store....it was high temp, ceramic, and resistant to brake dust (a must)...anyway the wheels turned out perfect...
Old Apr 16, 2009 | 04:40 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I did my wheels with Duplicolor wheel paint. I used their etching primer for the primer after sanding with 300 then cleaning alooot.Then about 4-5 coats of silver and 3-4 coats of clear. Here's how they turned out:
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
kitt23
Exterior Parts for Sale
Nov 28, 2015 06:26 PM
dbrochard
Oct 10, 2015 01:03 PM
dbrochard
Oct 10, 2015 01:02 PM
