Violent shaking while braking
Old May 24, 2009 | 03:34 AM
el_dookie's Avatar
Hey guys,
I've done my search and haven't really found a good enough explanation. i've always loved 3rd gen camaro and i'm finally willing to get one. This is an 88 z28. It's going for $1500 in my area. It has some sort of suspension problem. While braking the front end starts to shake very violently. If you depress the brake pedal and press it again it goes away, depending on the amount of pressure you use.
In my search for this issue, I noticed alot of focus on the rotors being warped. Could this be the issue? The guy that owns the car says that the problem is blown shocks that causes the car to shake like that. I want to know what your opinion is.
Old May 24, 2009 | 06:43 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Violent shaking while braking
$1500 for a Z28 that GM did not make in 1988???? I would lean to the warpped rotors first. But I would not rule out the front struts & strut mounts.
I would check this car closely, even for that money. Sounds like a poorly maintained car with a shakey history.
Old May 24, 2009 | 07:10 AM
el_dookie's Avatar
Well if you actually want to know the whole scoop of it. Outside stickers say Z28. By this i mean on the side skirts and also on the back bumper. BUT, the interior dash has the 25th Anniversary emblem on the passenger side. Could it possibly be a frankestein? Maybe.
Back to the issue. Rotors, struts, strut mounts. He told me that he replaced them a couple months ago. Could there be another culprit?
Old May 24, 2009 | 07:25 AM
DJP87Z28's Avatar
Sounds like a Franken car, unless you want the unknown problems walk away.
Just my opinion.
Old May 24, 2009 | 07:41 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
buying a car that was never made - with fake everything on it - i would not even rule out that it is not even an 88. or maybe it was a salvage that was given a bit of a face lift.
run away and spend your 1500 on something else.
Old May 24, 2009 | 07:46 AM
GOATS2QUICK's Avatar
Car: 89 trans am / 67 gto
Engine: 350TPI
Transmission: AUTO
Axle/Gears: 3.27 9 bolt
bad rotor, loose caliper, loose spindle nut, loose strut bolts,
you need to look close.
Old May 24, 2009 | 07:47 AM
Car: 1990
Axle/Gears: stock
look here https://www.thirdgen.org/forums/cama...8-305-tpi.html and it is real - and i bet he has all the records on it.
92firebirdguy
Sep 1, 2016 07:53 AM
88rscamar0
Sep 23, 2015 09:08 PM
Amillionoh7
Sep 5, 2015 11:44 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
