Unbolting K Member
Old Jun 9, 2009 | 12:52 PM
wshbrn91's Avatar
Car: 1986 Z28 Camaro
Engine: Rebuilt 82' 305
Axle/Gears: Non-Posi stock =(
Unbolting K Member
Hey all,
Just curious. When I unbolt the K member, do I just back out the bolts? or is there a nut on the other side of it somewhere that I need to get to?
Any other hits/tricks/warnings for me?
Thanks guys,
-Andrew
Old Jun 9, 2009 | 03:47 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Unbolting K Member
there are captured nuts inside the frame rail, all you have to do is take the bolts out.
So long as the engine is supported, the springs are out, and you didnt forget to unbolt the brake lines that running on top of the k-member, you should be fine.
Pac J
May 17, 2020 10:44 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
LT1Formula
Oct 8, 2015 08:34 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
