trailing arms
Old Jun 22, 2009 | 12:34 AM
monsterjam5000's Avatar
trailing arms
I was talking to a guy i know, he had just bought a 1992 camaro with aftermarket trailing arms. when i looked close i noticed they did not have bushings just a hole drilled in them with a thick bolt.
my question is why are they like that, is it a racing thing? what are some pros/cons of these type of trailing arms?
Old Jun 22, 2009 | 08:40 AM
UMI Sales's Avatar
Re: trailing arms
Their should also be a sleeve that the bolt goes through. That set up would be ok for a racing application! But when it comes to the street I would highly suggest going with a poly bushing. Going with the certain set up would still give you the comforts of a good ride quality. But if you are looking for a racing set up I would suggest going with at least a single adjustable or even a double adjustable to allow you to be able to fine tune the rear end. Below is a link to show you what all UMI Performance has to offer!
http://umiperformance.com/products.php?category_id=119
If you have any other questions feel free to ask and I will be more than glad to help!
Brad
Old Jun 23, 2009 | 09:33 PM
Re: trailing arms
alright thanks just i have never seen that done before. now that i noticed it i see it more and more offten.
Old Jun 24, 2009 | 06:42 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: trailing arms
good advice, but dont use poly on the rear control arms.
use either rubber or rod ends or jimmy joints, johnny joints... whatever they are called.
UMI is good
also consider:
SPOHN
HOTPART
BMR
any of these guys are better than stock and running a bolt through the arm.
Old Jun 25, 2009 | 11:11 AM
BMR Sales's Avatar
Former Sponsor
Re: trailing arms
Hello, we offer several different styles of lca's. They are available with urethane bushings, rubber bushings or QA1 rod ends. They all have a different purpose and are available in adjustable or non adjustable versions. Give me a call here at the office and i can explain what the benefits of each type are.
Attached Thumbnails trailing arms-tca001.jpg   trailing arms-tca004hsmall.jpg   trailing arms-mca001.jpg
no green
Jan 9, 2016 09:22 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
