LCARB Cons?
Old Jul 5, 2009 | 06:14 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
LCARB Cons?
I know the advantages of running the control arms in the lower holes in the relocation brackets, but are there any disadvantages to it?
Old Jul 6, 2009 | 06:31 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: LCARB Cons?
From what I understand, if you get it too low, it can cause problems under braking. Upsets the suspension
Old Jul 6, 2009 | 09:42 AM
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
Re: LCARB Cons?
More likely to get brake hop.
During hard cornering, the rear axle may want to run a little wide. You'll probably have to be a little more careful about adding lots of throttle as you exit corners.
The above situations are more noticeable when the car is left at or close to OE ride height than when lowered.
Norm
Old Jul 10, 2009 | 11:39 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: LCARB Cons?
It'll hop like crazy when you're backing up too...
You can overdo it, and have the rear end jump, and remove weight off the tires after a few feet down the line. Set the LCARB bolt holes for your best 60' time.
Old Jul 10, 2009 | 02:48 PM
Shagwell's Avatar
Car: projects.......
Re: LCARB Cons?
With they're to low you can induce roll steer. - As one side compresses the arm gets closer to level, while the other side extends, thus getting even further away. So the compressed side is pushed back, while the extended side is pulled forward, thus turning the rear end under the car.
Also, as Sonic noted, excessive angle will cause too much initial "hit" thus causing the tires to unload. Tighter shock valving would negate much of this, but would also hurt the supensions' reactions down track and make the car considerably more stiff.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
djmarch
Oct 2, 2015 10:41 PM
3.8TransAM
Sep 17, 2015 02:16 PM
scotrans am
Sep 5, 2015 04:26 AM
mike40sm2
Sep 1, 2015 02:15 AM
