how to determine sway bar size??
Old Jul 17, 2009 | 12:22 AM
LVZ2881's Avatar
Car: 1988 IROC
Transmission: 5 speed
Axle/Gears: 3.08 Posi 10 Bolt w/ aluminum drums
are the sizes the diameter or circumference??
whats the easiest way to determine what size I have so I can order the correct poly bushings??
I have an '88 IROC..
Old Jul 17, 2009 | 06:26 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: how to determine sway bar size??
My guess is that you have a 34/24 combo. Take an adjustable wrench and apply it around the bushings, measuring the jaws after each application. Should give you a pretty good idea.
JamesC
Old Jul 17, 2009 | 06:28 AM
Twin_Turbo's Avatar
most likely 34/23.
Old Jul 17, 2009 | 06:32 AM
JamesC's Avatar
Originally Posted by Twin_Turbo
most likely 34/23.
Interesting. I've never heard of a 23 (though that means nothing). My 85 IROC was a 34/24 combo.
JamesC
Old Jul 17, 2009 | 08:38 AM
Twin_Turbo's Avatar
My 87 has a 34 & 23, the GTA has a 36 & 24. My buddies 88 has 34/23 too.
Old Jul 17, 2009 | 09:01 AM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
JamesC
Are you sure you mean the bushings, or rather the bar itself?
EDIT: Ahhh, I think I get it now. When you said "around the bushings" you just meant on either side of them...
Old Jul 17, 2009 | 09:05 AM
ICESTORM's Avatar
Car: 1989 Camaro IROC-Z
Engine: 350 TPI L98
1 inch rear. 1 3/8 front.
Old Jul 17, 2009 | 02:35 PM
1988-305-tbi's Avatar
there is a 23mm bar, although it's not as common as the 24mm or 21mm,
NO!!!!!!
Old Jul 17, 2009 | 04:15 PM
JamesC's Avatar
I "assume" the IROC package contains the same components at least through 88. If so, I wonder why an 87 IROC would have a 34/23 combo while an 85 would have a 34/24?
As general info: Some camaros weren't equipped with larger bars until 89, IIRC, while some Birds got them as early as 86.
BTW, I meant a 23 on an IROC.
JamesC
J-money
Jan 4, 2019 09:45 AM
m00n420
Sep 11, 2015 02:39 PM
87camaro87
Sep 9, 2015 10:29 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
