what type of rear end?
Old Jul 31, 2009 | 03:07 AM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
ok so im not sure what type of rear end i have i think its stock but not sure. im also not sure at what type of rear end it is as far as posi or limited slip. what i do know is that the number on the diff is 22522676 and that when i jack it up and turn the wheels by hand one spins one way the other spins in the opposite. its been a while since i did anything with rear ends so what type is this. ok i'll stop rambling thank you for the help.
Old Jul 31, 2009 | 03:25 AM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
Re: what type of rear end?
posi and limited slip is the same thing. if you spin one and the other goes the other way its OPEN differential. posi=LSD (limited slip differential). open diff will give you the ol one wheel peel. you got yourself a peg leg, you can get an LSD from 100-300 bucks. chances are its stock. idk why somebody would pop in an open diff.
Old Jul 31, 2009 | 03:52 AM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
damn i got me a tripod
Old Jul 31, 2009 | 06:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Or a non-functioning limited slip. Check the following FAQ for more info:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
