Loud clunk when de-accelerating on my 83 trans am
Subscribe
Aug 18, 2009 | 11:26 PM
The guy i bought it from said the torque bar that runs all the way back from the tranny to the rear differential needs a new bushing. im not quite sure if that what it is and i was wondering if anyone has expirenced this problem and could tell me whats wrong. We thought it might be a u joint but they seem fine.
Reply 0
Aug 19, 2009 | 06:47 AM
Re: Loud clunk when de-accelerating on my 83 trans am
Try checking the tranny mount first. A common 3rd gen problem.
Reply 0
Aug 19, 2009 | 07:41 AM
Quote: The guy i bought it from said the torque bar that runs all the way back from the tranny to the rear differential needs a new bushing. im not quite sure if that what it is...
The torque arm is a long piece that runs parallel to the drive shaft from the rear end to the trans. There should be a bushing on the trans end. More likely, though, it's, as DJP mentions, the trans mount (the mount supports/cushions the tail shaft of the trans). A poly replacement for either is your best bet.
JamesC
Reply 0
Aug 19, 2009 | 09:22 AM
Hello
Like mentioned above check the bushing they usually get cut! And make sure the hardware to the torque arm is tightened to specs. If you do need a replacement poly bushing we also offer those for $14.99 plus S/H. If you have any other questions or concerns feel free to ask and I will be more than glad to help!
Brad
Reply 0
Aug 20, 2009 | 03:24 AM
. Trans mount. Later.
Reply 0
Aug 25, 2009 | 03:20 PM
would I be out of place if I said check the trans mount?
Reply 0
Aug 25, 2009 | 03:30 PM
Quote: would I be out of place if I said check the trans mount?
No one like a wiseacre, Dan .
JamesC
Reply 0
Subscribe
