rattle noise and 2 rims are further.
Car: 86 trans am
Engine: 305 tpi
Transmission: really crappy 700r4
hello i have two questions, didn't know whats making the rattle noise so i put it here. whenever i go over a bump something in my rear end rattles?! has anyone had this problem before? the other part to it is that whenever i go over a bump and I'm on the brakes it prevents it from rattling. Could it be the brakes themselves that are rattling?
Also i have the stock 16in 86 ta wheels and i noticed that two are set in further than the other two. Which ones are for the front and back? or does it not matter? They were randomly placed on the car when i bought it.
2011 Norwood Gathering
ThirdGen Camaro Rep
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
Re: rattle noise and 2 rims are further.
The rattle sounds like the pads, does the car have rear disc brakes?
Car: 1991 Firebird
Engine: 3.1L V6
If you look on the back side of the wheels, it tells you FRONT or BACK on them.
Car: 86 trans am
Engine: 305 tpi
yes it is rear disc brakes, my friend claims we did it right but when i took the tire off they moved... how do i fix it?
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
sjorgens
Oct 1, 2015 07:54 PM
