front suspension/k member
Old Oct 20, 2009 | 01:02 AM
  #51
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: front suspension/k member
Originally Posted by 572_Rat
Weaz, I hope this helps you, I have an 86 Iroc, I used a Racecraft K-member, A-arms, dropped spindles shorten for rack, bump steer kit, unisteer rack and pinion, Moog 5662 springs in front. PA racing steering shaft kit. I used a 28" tall Mickey Thompson up front. Car handles great, I have no less steering radius than I did factory, and have had zero problems with bottoming out or my lower spoiler hitting anything. I also used Koni yellows, Spohn sway bar and adjustable wonder bar, J and M stut mounts and Edlebrock 3 point strut brace.
In fact I can guarantee that the car handles better now than it ever did factory, and I love the look of the stance of the car. The car goes around corners with no body roll. My car is 100% street car, it is not a daily driver but very enjoyable to drive
https://www.thirdgen.org/forums/susp...ml#post4312038
Old Oct 20, 2009 | 07:16 PM
  #52
weaz4200's Avatar
Car: have a 92 camaro rs...in pieces
Engine: none now...probably 383 stroker
Transmission: none yet
Axle/Gears: none
Okay so heres a few questions... As far as the K-member... They have the 4130 and the mild steel... At what power range do i want to use the 4130 v.s. the mild steel??? Cause im lookin to do around 500HP... Now, i noticed while lookin at the racecraft site they have these 2, http://www.racecraft.com/index.php?m...roducts_id=259 and http://www.racecraft.com/index.php?m...roducts_id=524 .... The first has the option for spring perches and rack mounts... So one.. Does that mean that the 2nd one does come with/have rack mounts???? N the other question is, what are spring perches?? .... In one thread a guy said...
the k member with spring perches allow you to use factory coil springs as opposed to using a coil over kit.
So based on that statement am i to understand that if i dont go with spring perches i can only run a coil over setup??? If that is the case..then the 2nd K-member for $400 will only work with a coil over since it doesnt have that option??? Maybe someone can clear that up for me... Those A-arms were from Racecraft??? 572_Rat... It looks like your runnin a spring in stock location.... i could be wrong... But on Racecrafts site i didnt see a-arms that utilize a stock spring location.... Maybe u could clear that up as well.... Thanks for the help so far guys.... Also.. Not sure if i mentioned this... but i wanna run stock spring setup up, not coil over... So as of right now i got some dough and im lookin at just gettin the K-member and the A-arms (with all mounting hardware)... I got all the old nuts and bolts, but i likes new... So what brand do you recommend i go with, and are brands interchangeable??? Like can I go with a Spohn k-member n Racecraft a-arms n vice versa???? I got about a G to spend.... So gimme some input please... Thanks.. Later.
Old Oct 20, 2009 | 09:56 PM
  #53
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Originally Posted by weaz4200
Okay so heres a few questions... As far as the K-member... They have the 4130 and the mild steel... At what power range do i want to use the 4130 v.s. the mild steel??? Cause im lookin to do around 500HP... Now, i noticed while lookin at the racecraft site they have these 2, http://www.racecraft.com/index.php?m...roducts_id=259 and http://www.racecraft.com/index.php?m...roducts_id=524 .... The first has the option for spring perches and rack mounts... So one.. Does that mean that the 2nd one does come with/have rack mounts???? N the other question is, what are spring perches?? .... In one thread a guy said... So based on that statement am i to understand that if i dont go with spring perches i can only run a coil over setup??? If that is the case..then the 2nd K-member for $400 will only work with a coil over since it doesnt have that option??? Maybe someone can clear that up for me... Those A-arms were from Racecraft??? 572_Rat... It looks like your runnin a spring in stock location.... i could be wrong... But on Racecrafts site i didnt see a-arms that utilize a stock spring location.... Maybe u could clear that up as well.... Thanks for the help so far guys.... Also.. Not sure if i mentioned this... but i wanna run stock spring setup up, not coil over... So as of right now i got some dough and im lookin at just gettin the K-member and the A-arms (with all mounting hardware)... I got all the old nuts and bolts, but i likes new... So what brand do you recommend i go with, and are brands interchangeable??? Like can I go with a Spohn k-member n Racecraft a-arms n vice versa???? I got about a G to spend.... So gimme some input please... Thanks.. Later.
I chose the Racecraft due to price and quality, other k-members are just as good or maybe better, but price was the best with them. They A-arms and K-Members come with or without spring perches, I chose spring perches, because I am not a fan of coil overs on these cars, just personal preference.
To see if they will interchange I would contact the manufactors, I know if I was doing this again I would still have used there K-Member ( Road Race Version) I would just hope you would not have to go through all the screw ups I had with them, but I would use Spohn A-arms, I think Spohns A-arms are a better piece. I spend more than a grand, I think my bill with Racecraft was about 2200.00 but that also included 4 piston brakes up front, and a couple hundred more with Spohn. With the J&M strut mounts, and all new bolt hardware ( if you are going to spend the money on these parts, please put in new bolt hardware ) it was about 2700.00
Old Oct 20, 2009 | 10:11 PM
  #54
weaz4200's Avatar
Axle/Gears: none
If you are going to spend the monney on these parts, please put in new bolt hardware
I wouldnt have it any other way....Does the racecraft one come with all the hardware??? Cause i still got all the bolts...But i wont reuse any of them... PLus i dont remember where all of them are..LOL. So i guess the only questions i have are.... 1... Do i really need it to be chromemoly???
2... Whats the road race version???
Are the 2 k-members i posted links to fine???
and 3... As far as their options... Do i want their motor mounts??? (doin a 383) and 4th gen rack or pinto (depending on which one...elaborate)??? Also where's the best place i could get a deal, not cheap quality but somewhat easy one the ole wallet?? U also said u got a unisteer rack and pinion.... Since they dont have one specific for the 82-92 camaro... Can i use any of them... Or am i limited to a 4th gen or pinto???
Also got a question bout the Spohn a-arms... but ill ask that in a bit... dont wanna throw too many ?'s out there...
Old Oct 20, 2009 | 11:16 PM
  #55
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
the one specific to the camaro IS a pinto rack...
road race version is stronger and more braced, but weighs more. road race is as opposed to drag race version, where weight is a premium concern
integrated motor mounts are a great option if you get a k-member with integrated mounts.
if not, you can put motor mounts on any k-member
the integrated mounts are simply welded in for extra strength and stiffness
hope this helps
Old Oct 20, 2009 | 11:30 PM
  #56
572_Rat's Avatar
1) No I don't think you need chrome moly, I chose to use it because it is stronger and lighter, for a street car mild steel would be fine
2) Road race version just has extra bracing, to make it stronger for cornering
3)You want mounts ( these are frame mounts, not the ones that bolt onto the motor) unless you are using motor plates. For rack mounts you need to decide if you are going with the pinto rack or 4th gen. The unisteer rack they used is shorten for the 3rd gen Camaro
Old Oct 20, 2009 | 11:40 PM
  #57
weaz4200's Avatar
Axle/Gears: none
When i was looking at the k-members it doesn't say which one it is... So then the pinto would be manual and the 4th gen a power rack??? Say i want to use a 4th gen rack, i dont see one on the Unisteer site... So how do i figure out which one to use??? Also as far as a power rack goes, hows that set up??? Its basically a rack with the lines goin from the PS pump to the rack like this???? Do u need custom lines or something?
Old Oct 20, 2009 | 11:48 PM
  #58
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Also as far as a power rack goes, hows that set up??? Its basically a rack with the lines goin from the PS pump to the rack?? I couldn't find that out.
Correct.
HP isn't relevent to chosing k-members. The only real anvantage to CM is that it is stronger, and since it is stronger thinner material is used, so the CM k-member will weigh less. You don't really gain much strength with CM.
Unless you buy a kit, you will probably need custom lines, but they are easy enough to make.
Old Oct 20, 2009 | 11:50 PM
  #59
572_Rat's Avatar
When i was looking at the k-members it doesn't say which one it is... So then the pinto would be manual and the 4th gen a power rack??? Say i want to use a 4th gen rack, i dont see one on the Unisteer site... So how do i figure out which one to use??? Also as far as a power rack goes, hows that set up??? Its basically a rack with the lines goin from the PS pump to the rack?? I couldn't find that out.
I have not been on Racecraft website for a long time but they used to show pictures of their road race version, in fact it was mine. For a 4th gen rack go to a salvage yard or auto store and get a rebuilt unit or buy one new. I don't know if unisteer or flaming river sell OEM parts.
Yes, PS pump lines go to the rack
Old Oct 21, 2009 | 12:02 AM
  #60
weaz4200's Avatar
Axle/Gears: none
I see... So if thats the case then droppin $250 extra on a Spohn k-member just to get it in CM is not really worth it... I think im gonna learn more from u guys than i will at school... Some of u guys should be teachin my classes, instead of the instructors i got. I hope to be as knowledgeable one day.... So this is my last question for tonight, then im out... 572_Rat... So either i get a pinto rack mount or a 4th mount??? But i recall u sayin u got the racecraft k-member and a unisteer rack... So what mount did u get when u ordered ur k-member??? Thanks.
Old Oct 21, 2009 | 12:10 AM
  #61
572_Rat's Avatar
The unisteer is a pinto manual rack
Old Oct 21, 2009 | 12:13 AM
  #62
weaz4200's Avatar
Axle/Gears: none
Cool... I guess ill look at maybe a 4th gen rack then.... Later
Old Oct 24, 2009 | 01:54 AM
  #63
weaz4200's Avatar
Axle/Gears: none
So i ended up orderin the Spohn a-arms and the Racecraft k-member... Had to call them and tell them what i wanted. Im surprised that on their site they dont have the options listed like with the 4130 they show... Plus from what i understood after talking to one of the guys, he said that the MS one is advertised for the coil over setup. I find that odd, cause the third gens usually didn't come with a coil over setup. Or did they have that option? Anyways, hopefully i wont have any problems with them like 572_RAT stated he had (whatever that may have been). Should be gettin the parts next week and on the car by next weekend... Hopefully. Thanks for all the info guys.
Old Oct 27, 2009 | 02:16 PM
  #64
weaz4200's Avatar
Axle/Gears: none
Im excited, got my a-arms... Thank you Spohn, very quickly processed and shipped instantly, nice... Now i wait for Racecraft, im assuming the have to make my k-member as they didnt have the a stock coil setup ready,which i still find odd.... But when i called the guys said it got held up in powdercoat n tomorrow it should be here.... Or so he says. Now maybe Spohn can make a spindle with stock spindle height n shortened steering knuckles, they got a few drop spindles but not for the 3rd gens.
a-arm2.jpg?t=1256670595
Old Oct 28, 2009 | 05:49 PM
  #65
weaz4200's Avatar
Axle/Gears: none
As usual, got both the a-arms and the k-member and they dont match up.. So what to do now, and whos fault is it. The rear bushings on the a-arms and the mount for them on the k-member are good. The issue is the front. The bushings on the front measure 3.023" and the mount spot on the k-member is 2.903 (2.900, somwhere around there) So now i dont know if the bushings are too big or the k-member mount is too small. What do u guys think? Anyone know what the front bushings/k-member should measure?
Old Oct 28, 2009 | 06:09 PM
  #66
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
are the bushing in the a-arms all the way together? they are 2 pcs and may not be totally seated. I would call racecraft and ask if their k-member is supposed to work with stock a-arms. If they say yes, they messed up. I would like the think Spohn know how to make a-arms by now.
Old Oct 28, 2009 | 06:31 PM
  #67
weaz4200's Avatar
Axle/Gears: none
Yup, but even if they weren't, it couldnt be .100" off, thats a lot. In fact, I just went out and measured the stock ones i had on the camaro and they measured close to what Spohns are, Spohns are 3.023" and the stock ones are 2.992 (probably from wear and tear). So what should i say to racecraft? That i want them to make me a new one and that since they f-ed up they should reinburse me some how, because i gotta send it back (extra shipping) and its wasting my time since i could be installing it? I was hopin this wouldnt be the case, but like 572_RAT said
(about racecraft) So i guess that makes 2 of us.
Old Oct 28, 2009 | 08:46 PM
  #68
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I would take the bushings and sleeves out of the A-arms and just trim them a little bit. Take it to a machine shop and have them cut them down a little. Shouldn't take more than a couple $ or minutes.
Or, take the opposite approach, and take a piece of threaded rod and stick it in the A-arm mount, and with a pair of nuts on the threaded rod, turn them in opposite directions to spread the A-arm mount apart enough to get the A-arm in. I know this works on stock K-members, but I don't know if it is safe to do on yours, might damage welds and the powdercoat.
I would go with option #1, or call up racecraft.
Old Oct 28, 2009 | 09:12 PM
  #69
weaz4200's Avatar
Axle/Gears: none
That could be done... The messed up thing is that they make a mistake and i gotta pay... What does that say about them. I even asked them if other a-arms will work, they said yea. Not sayin they did that on purpose but say i didnt get aftermarket a-arms, the stock ones wouldn't work either.. Way too small a measurement. Sorry, i know my b***chin doesnt belong here, but im just peeved. Plus others may want stuff from them, so i figured id post my experience.
Old Oct 29, 2009 | 01:25 AM
  #70
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
If you are more concerned about time, you could use a band saw to trim the bushings, or really any method of cutting them, but if you don't leave a clean enough finish they might squeek.
I would take the sleeve out of the bushing, and measure that by itself, see if it alone will fit in the new k-member.
Really, it is Racecrafts fault. If your stock A-arms don't fit, (I would actually try to install them to be sure) they are obligated to make it right. You shouldn't even have to pay any shipping.
Old Oct 29, 2009 | 03:26 AM
  #71
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
was about to make a order with racecraft for a K member. and get spohns coil over set up..and A arms...LOL
so whats the deal..
when i talked to Spohn this week. i got a code for $65 off my order
so if i pay them for
the K member..coil over set up.. and A arms + shipping it was $1389
buying from 2 diff places even with lower cost parts it was still $1391
so it looks like it's all Spohn parts for me..
thanks for the Heads Up Guys
I Love Visa...
Old Oct 29, 2009 | 10:51 AM
  #72
Guest
Guest
Posts: n/a
First off, I would not cut or trim the a-arm bushing at all!
A-arms are tight to fit with new bushings, especially urethane. However, you did measure the ears of the kmember and the bushings on botht he new and old A-arms so you have confirmed Racecraft is a fault. Simply call them and tell them to send you a "call tag" for shipping. Tell them exactly what you did and how you know its them. You have checked measurements on both arms and niether old nor new will fit but will fit your existing kmember.
I just don't get it, how can a manufacturer make a mistake like this unless they are altering one jig for multiple uses. They should have a fixed jig to bolt the parts to and then weld everything together. No reason for this type of error.
Old Oct 29, 2009 | 11:00 AM
  #73
Guest
Guest
Posts: n/a
I will also add that trimming the bushing potentially cause many problems.
1) not the correct factory bushing size. So future replacement will always be an issue.
2) if not done correctly, there will be metal on metal contact unless the bushing is pressed out and the mount housing milled smaller on the correct end (to which the next question lies...which is the correct end). Then one side of the inner uretahne needs to be milled shorter and the center metal sleeve milled shorter. Finally it needs to be re press fitted into the A-arm.
3) if not done in the manner I describe, then metal on metal contact will be made and the movement of the two pieces together can be later catastrophic.
4) most likely the problem originates with the Kmember mount ear is positioned not only shorter in width but wrong in articulation geometry to the other ear tab once the bushing is trimmed.
Again, don't cut the bushing. You will THEN have TWO problems with both a tappered useless Spohn A-arm and along with the faulty Racecraft kmember.
Old Oct 29, 2009 | 12:40 PM
  #74
weaz4200's Avatar
Axle/Gears: none
Yeah. I didn't plan on any cutting. N i did talk to them... I still find it funny that they asked why i went with Spohns a-arms and suggested i get theirs but keep the k-member the way it is cause they would rather not have to make another one... Thats what i was told. Plus i started to think, if i did that, then if i ever needed new bushings id have to get them specially made under tolerance... N i wont do that... So today i spoke with one of the guys... He said he'd take care of it. I gotta weigh the a-arms, send it to them (they cover cost/shipping) with the k-member and they make me a new one and use my Spohn arms to make sure theres not another mixup... I still find it stupid that i have to send them the a-arms for them to match it up... I got a simple answer for them.... Make a new one with the rear measurements they initially had, but make sure the fronts measure 3.000" so the 3.023" oversized Spohn bushing will work.... Sounds simple to me.
Old Oct 29, 2009 | 01:36 PM
  #75
Guest
Guest
Posts: n/a
Its a tough call. I would just send the thing back and get my money back. These guys can't make things to factory specs without "your parts"...give me a break.
ps- Spohns bushings are NOT oversized. they are simple new bushings and urethane gives slightly when you force them into the kmmber. It you measure just the center steel insert sleeve, I promise you that is not over 3.000.
0.023 is nothing, you can practically squeeze that with your hand out of 3" wide urethane. You want them snug but greased.
As I stated before, I would never replace a factory kmember on a car for something lighter weight unless it was a full time drag car. If its used on the street at all? no way. I choose the beefy stock unit. Just my opinion on safety when it pertains to road debris. I have hit many hard objects on the road at high speed. One lighter blow was a damn retread that wiped out my front splitter a few months back on my truck I was changing lanes and there it was blinded behind the car up in front of me. Everything under there took a blow when that lexan splitter came off and shattered- there went almost $500. It bent a few lighter weight metal pieces under there. I would hate for something to hit one of these flimsy little round tube kmembers, it would bend like no tomorrow.
People need to look at factory kmembers on any car as part of what they are designed so big and bulky for. They double as SKID PLATES!
Old Oct 29, 2009 | 03:47 PM
  #76
weaz4200's Avatar
Axle/Gears: none
So now i got a dilema, got a message from spohn and they dont have a k-member for power rack, plus, and i quote from them...
The 4thgen rack is not a good choice for a thirdgen.
So i should return the racecraft k-member and get one from Spohn with manual rack mounts or get a new one from racecraft and go with it.... Why would Spohn say the 4th gen rack is not a good choice?
Old Oct 29, 2009 | 05:31 PM
  #77
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
The 4th gen rack might be a bad choice because of how it mounts or possibly its range of motion. Ask Spohn.
I'd give racecraft a chance to make things right, but if they screw up again or if it will cost you any additional money, go with another brand.
Old Oct 29, 2009 | 05:44 PM
  #78
weaz4200's Avatar
Axle/Gears: none
When i get a chance i will, they also said this...
We are working on a power rack set up that will be designed to work correctly on a thirdgen. That should be out sometime this winter.
Yea, ill probably do that. Still think its dumb that they need my Spohn a-arms to match it up, but oh well.. S**t happens, everyone deserves a second chance....
Old Oct 29, 2009 | 10:19 PM
  #79
572_Rat's Avatar
https://www.thirdgen.org/forums/susp...racecraft.html
I hope you have better luck than I did about them fixing your problem, I gave the link to the challenges that I had. One thing after it is done you will have a good piece, they really do make a good product, it is the screw ups that **** you off. Don't expect to get compensated for your time.
BTW Spike how did your racecraft air bag setup work for you
Old Nov 14, 2009 | 06:39 AM
  #80
weaz4200's Avatar
Axle/Gears: none
So i ended up with the Spohn k-member instead, but now im curious if any of you guys have the Spohn piece as well? The reason i ask is because i was curious about the fitment. All the bolts line up and it seems like everything is good except that the mounts that hold the coil spring are in different places when comparing sides. Theres the flat part on the frame which then tappers down... I may not be explaining this right so here a 2 pics... The first is the drivers side, the other passenger....
k-memberprob4.jpg?t=1258195793
k-memberprob3.jpg?t=1258195921
As you can see, the drivers side sits flush againt the frame all the way up to where it starts to angle down. Now comparing that the the passenger side which you can see that theres like a half inch or so between the k-member and the part that angles down (both sides marked in red)... I called Spohn and the guy told me that its normal, thats how they are... So i wanted to hear what you guys think or if anyone else has noticed this with theirs? I would think that theres nothing wrong with my car, no accidents on the carfax. Plus everything went in like a glove. Thanks.
Old Nov 15, 2009 | 06:08 PM
  #81
//<86TA>\\'s Avatar
Car: 86 Trans Am
i dont know how symmetrical the factory k-member is. It may be off just like your spohn piece for whatever reason.
what i would do is measure center to center the spring perches in the factory k-member and compared to the spohn piece.
Old Nov 16, 2009 | 01:34 AM
  #82
weaz4200's Avatar
Axle/Gears: none
It seems pretty close, measured it from close to center of each side of the stock k-member. I would just hate to have all my parts in a few months or so down the road and find that it might be an problem if it is in fact off by a little... Are there any other measurements I could take? Like from the k-member to certain parts of the body? I was thinking of somehow measuring from the a-arms to like the center hole of the strut towers where the caster/camber plates go but im thinking my car would have to be sitting level maybe....Or am i just gonna have to wait and see once i get and install more parts?
Old Nov 16, 2009 | 06:34 PM
  #83
//<86TA>\\'s Avatar
Car: 86 Trans Am
if the upper spring perch is off just a hair, it wont be an issue. More than a half inch, could be a problem
Old Nov 16, 2009 | 07:32 PM
  #84
after shoping for all the front end parts for My 92 Z28 im going to Buy every thing from PA RACING $850 SHIPPED all Bolt in.
http://www.paracing.com/catalog/prod...products_id=82
Old Nov 16, 2009 | 08:09 PM
  #85
//<86TA>\\'s Avatar
Car: 86 Trans Am
how many sets of things are you goiung to buy, jeebus, wish i had that kind of money
Old Nov 16, 2009 | 08:45 PM
  #86
572_Rat's Avatar
Just to let you know, all PA racing K members and a-arms were originally made by Racecraft and resold under PA Racing name, I don't know if that is still the same, there was a post on here sometime ago, Mark had stated that they did all PA racing K-Members
Old Nov 16, 2009 | 11:57 PM
  #87
weaz4200's Avatar
Axle/Gears: none
Can you guys post a few links of threads that I could read, as so I could find out and understand how to choose the following parts.... Spring Length/rate, Shocks/struts (rates), Caster/camber plates (what a 1" raised would do), Bumpsteer... I need to be pointed at the right direction for a starting point. As this is my first build i dont know much, hence id appreciate if someone could tell me what I should look at first. So maybe in order to understand suspension, id have to know a arm geometry or how shocks/struts/springs work under different applications... Get what im sayin?
Old Nov 20, 2009 | 09:32 PM
  #88
weaz4200's Avatar
Axle/Gears: none
I think im making this more complicated with too many questions at once... So i'll ask about 1 thing at a time.. The first is.... The Camaro has struts up front and shocks in back, but say hawks third gen. They have a front Camaro/Firebird 93-02 front shockwhich looks like the rear that my camaro had, but the fronts are called struts... I dont get it other than design, whats differentiates it from being called a shock v.s. a strut? The other thing is coil springs... Both these have to be matched up, so ive been told... Umtimate question is how do i got about choosing the right shocks/struts and springs to order? How do i figure out what the valving needs to be or what spring rates i need?
Old Nov 21, 2009 | 05:02 AM
  #89
FOR THE $800 PRICE and getting all 3 parts..and all made to work together..thats the Big thing..
no hacking of parts to try to get them to work..
did not see anything from Racecraft in a front end Kit for the 82/92 Camaro
listed. PA is $799 for there Kit.
Just want the parts to.. work with ea other.. bolt in..and run..
spring rate is worked out after you have it all together.
Old Nov 21, 2009 | 10:18 AM
  #90
Guest
Guest
Posts: n/a
Its caled trial and error. Every car is different. I went through 3 diffemt coil sets on the front of my car til I had the result I wanted.
Old Nov 21, 2009 | 10:49 AM
  #91
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
as far as shock vs strut. a strut supports the upper part of the spindle. a shock will not take that load/not setup to bolt up the same. 93-02 Camaro/Birds use lower and upper a-arms; that is why they have shocks on the front. being that our cars don't have upper a-arms, we have struts.
Old Nov 21, 2009 | 01:19 PM
  #92
weaz4200's Avatar
Axle/Gears: none
Its caled trial and error. Every car is different. I went through 3 different coil sets on the front of my car til I had the result I wanted.
That i understand, but where do i start, thats what im askin. I mean you have to have a starting number as far as springs go. As well as a starting point for choosing the correct shock/strut valving to match up with the rates of the spring. It seems that Vetruck wont be helping me anymore so this is directed for anyone else that wants to help... So im looking at the Koni Sport Yellow adjustable rear shocks/ front struts as well as the Caster Camber Plates (J&M)... Both from Hotpart... A drop spindle from either RACECRAFT or AJE. So with the spindle id use a stock height spring up front and a 2" drop srping in back... Does that sound about right? Since AJE's spindle is a 1.8" do i need to get a spring with the same amount drop in the rear? Do they even have springs with that measurement drop? The last is sway bars dont, even know where to start... So what do guys think? I need shocks/struts, springs, and sway bars for now. Any input?
Old Nov 21, 2009 | 05:39 PM
  #93
Car: 91 Camaro
If you read through the threads "ultimate suspension" (which happen to be written by vetruck) you will find some suggestions on springs and shocks/struts, and sway bars. Sounds like you've got a decent idea of where to start with the list of parts. As for rear springs and x amount of drop, you can always trim them down if they're too long.
Old Nov 21, 2009 | 06:58 PM
  #94
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Get the front end set up, see how it sits, then get rear springs to match. That's what I would do, at least. You're probably wanting to get something in the 800/850 front and 150/175 rear as a starting point. I don't know what free lengths you'll need (determines ride height), but those are the rates that I've heard would work well on performance-oriented street driven car. You'll either want an adjustable set of sway bars for the car or several sets of stock bars to play around with to dail it in.
Old Nov 22, 2009 | 12:35 AM
  #95
Guest
Guest
Posts: n/a
Weaz, in all due respect, as I said in a PM its not that i do nopt want to help you. The problem is I personally feel you do not know what direction you even want to build to. When I first asked you what your intentions for the car are, you replied:
Daily driver?
NO
AutoX? full time, part time
NO
Drag car? full time, part time
15%
Weekend cruiser/ garage queen?
50%
Show car?
35%
Its kinda hard to really know as far as drag... I do know that with as much power as i want, i definitely wanna utilize it... Just dont wanna F something up... My pockets aren't that deep... As this is my first build.. I wanna learn how things work as well, not just build it and be done. It wont be driven other than the summer and spring/fall when its not raining. No winter what so ever... Unless the garage is on fire and i gotta save her. Plus i was also thinking of converting to manual trans... I got a lot ideas... Just hoping i will actually get it put back together...
Then in a PM I asked you again and you replied 70street/30 drag.
I can not help you if you do not even know what you want before you have already started buying parts without a real plan and investigations to that plan BEFORE you have already started just throwing money at parts that look nice.
I do not want to tell you what to buy next until you read more and stop buying parts first, then get a game plan and focus towards staying with that game plan. I think you just want a car with a bunch of trick looking parts under it so you can show it off? I this correct, if so, then just spend away on what you think looks good.
best thing I can teach you is....A car can be built basically for one purpose, not two.
I of all people am a hypocrite to my own words, but I also built my Vetruck knowing the maintenance a dual purpose vehicle would create and the suffering I will occur as a result of it still being....A TRUCK not a sports car. It bacially is a sports cart that wil carry 4000lbs in the bed. That cost me big bucks to do, and I have taylored controls in cockpit to aid in this to change the vehicle for its specific need. I do blow out shocks and bushings regularly though- solely because of the weight of the truck even unloaded, never the less its loaded weight going over dips and bumps and literally tearing metal parts over the years for R&D to it. Greygoose was just following me down a freeway a week ago a a 3rd gen meet and commented afterwards that my truck looks like a washboard going down the road its so race car...ish for a truck. It beats the hell out of passengers unloaded on long trips. Its not comfortable unless you are hard on it pressing and loading the suspension under throttle and brake.
Its bery hard to get any vehicle to double duty. Especially wwhen it comes to street and drag, they are so different.
Old Nov 22, 2009 | 05:23 AM
  #96
on the other hand.. if you want a drag car.. and you want to drive it on the street.. and do car show's and the sat nite out.. then put together a drag car..
back in the 80's in Las Vegas. the only way to be Fast on the street
from light to light.. or the fri/sat night street hang out. was to drive what your raced.. see you can have a fast street car..
But. take it to the track and you would get beat by a Race car..
so us Guys started doing race cars with street car Looks.. and it started getting FAST!
all the mags started picking up on it and before long you Had
out law super street! and cars running into the 10's.. THEN THE 9's
then the 8's. and the rules.
so for a few of us.. a drag car is a street car..
POWER windows
power locks
Cd players
nice Cumfy inside.
can drive it on the street.. or to work.. or the 150 mile drive on the week ends.
then rip a 9.99 PASS at the track..
or a tad bit slower pass of 10.34 (my car). it's all about fun..
and smoking the Guy with all the stickers on His Race car!!
one of the other things getting started back in the late 80's was the full size
trucks running 11's and 10's. that was always fun...
so do you want a drag car you tow to the track..or one you drive?
ya so you dront drift to much on the street alot.. with out looking like a kid.
or swapping lanes like somone running from the LAW!
but let me tell you this.. you can drive a drag car on the street with out going FAST at all.
and you will always LOOK COOL!
after all they start to get to know you and your car...soon your car has the rep!
it's all about having fun.
with the street car guys.. you will always get beat by the guy who wants to go faster!
how bad do you not! WANT TO GET BEAT!
(how bad do you want to have fun!)
making a fast car = Taking a nice car thats nice to drive. and turning it into a
parts busting finicky somtimes. pain in the *** to park. (away from others).
dont leav it anyplace over nite..
thats what it is..
and man it's fun!!
and you have to have more then 1 car.
my other car is a truck i have had for 20 years
4x4 and it 100% stock..
Old Nov 22, 2009 | 03:09 PM
  #97
weaz4200's Avatar
Axle/Gears: none
VEtruck, i agree. I myself have noticed im all over the place. Its just that its all overwhelming... Nice parts, yes. I want the parts to look nice, not only that, but i'd like them to perform properly. All in all, ive got the k-member and id rather not use anything stock... As far as the car use, id like it built for occasional shows but mostly the street... NOw when i said id take it to the strip, its not my #1 proirity, id just like it built so that if/when i do take it to the strip its built in a way that i could have descent runs with out worrying that ill break something too quickly because i had help building it (from you guys)... Its kinda like, say where talking about Subframe connectors. They from what i understand reduce flex, so that part helps with the street but the strip as well.. Get what im saying, Its not that i want the car to be a drag car or have a full suspension dedicated to drag, its just that id like to learn about and install parts that help the car. By that i mean, be it structure or speed or grip on the track as opposed to the parts that only benefit the street.. Or another example, say shocks/struts. Its possible to buy non adjustable, which would be cool for the street. Say i had adjustables, those could be a possible benefit in a race. Sorry for the long post, hope you all get what im saying... Plain and simple, just want it build with parts for the street yet have the parts be capable of pounding on them. Im not disagreeing with n e one here, You guys now more than me. Let me know what you guys think.. THanks... ROB
Old Nov 22, 2009 | 06:56 PM
  #98
Car: 91 Camaro
Most of the parts will take abuse from street use and/or racing application. If I were going to be running tubular k-member and a-arms (especially) I would plan on inspecting them from time to time looking for cracks or something of that nature. Those parts take some abuse, especially from holes in the road and that type of thing.
That's a somewhat more specific direction as far as what type of suspension you'll need. Your strut/shock and spring choices will vary a lot depending on if you want it setup for drag or autox. Technically, there are things you may want to do a certain way for street use. However, a car setup for (within reason) the drag strip or autox course will be drivable on the street.
Now, you've said street/strip is what you want. I, personally, would go with something along the line of Lakewood 70/30 struts and 50/50 shocks. You could keep stock springs, most likely. I'll let someone else chime in on spring rates/lengths. As far as k-member, a-arms, lcas, tq arm, and panhard bar...your choices are open to which brand you'd prefer, if you want aftermarket. If you lower the car, I would plan on lcarbs, as well.
Hope this is somewhat helpful to you.
Old Nov 22, 2009 | 09:14 PM
  #99
weaz4200's Avatar
Axle/Gears: none
Will do.
A car setup for (within reason) the drag strip or autox course will be drivable on the street.
That sounds good to me, thats what id like to have, something that will work on the strip (if i ever go) but be drivable on the street.
Why do you say that, Should an adjustable work as well, like the KONI's?
I know, because there are so many choices thats why im lost. Like say an adjustable sway bar, i thought that those work depending on the thickness so what adjustable has to do with it i dont know.
LCARB's for the rear right? Thats another thing, since im gonna install a rack, i was told id lose the turning radius. To compensate for that id have to get the spindle kunckle modified like the racecraft spindles have. So now i have to think... do i go with racecraft who i just dealt with and had seen another guy on the forum who got their spindles and had problems or other companies... Its things like that, that are making it complicated, either that or im just making it harder than it should be... Thanks AM91Camaro_RS.
Old Nov 22, 2009 | 10:12 PM
  #100
Car: 91 Camaro
Don't quote me on this because I don't have evidence to back it up. But, I believe that the valving in Koni's (even being adjustable) would be too tight for a drag setup. You need something with a low rebound valve to let the front suspension come up for drag. The lakewood 70/30 struts will do this. You could go with the 90/10s but that's probably a bit extreme for a car that will see much more street use than strip.
I don't know anything about an adjustable sway bar. Unless it adjustments on the endlinks or more likely a torsion bar (I believe is what they call them). Anyway, where the end links slip over a spline on a straight tubular bar. That's more of a race setup, especially not needed for street/strip. As for the other parts, I like BMRs stuff. Of course, they're local to me so...
LCARB is lower control arm relocation brackets. both sides on the rear axle mount. These will keep the lower control arm(LCA) parallel to the ground or slightly up (on the chassis end of the arm) when the car is lowered. Without the brackets, a lowered car will have the arm angled up on the axle end which will promote wheel hop or atleast loss of traction.
I don't see the real benefit to R&P steering. Yeah, there's a few pros but several cons... a big con being the potential difficulty of the install.
