Which STB for GTA hood?
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Can anyone recommend a strut tower brace that will clear a GTA hood, and work with aftermarket strut mounts? If I can't find one, I may have to get something fabbed.
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Re: Which STB for GTA hood?
I know the hotchkis STB works on the GTA but I need to ask my buddy what strut mounts he had, I'm not sure, sorry. I'll get back to you in a while.
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
the bmr strut tower brace fits with no modifications to the hood or tpi intake.. just need to bolt it next to the strut towers..... i have one and it really tighten up the front end and it looks nice too.... thank you bmr for making excellent suspension parts....
Car: 87 GTA
I had an Edelbrock 3-pt & the hood sat about 1/8" high in the rear. Not much, but noticeable, and that was with no underhood liner.
I test fitted the UMI 2-pt one for UMI & had to cut some underhood bracing to get the hood to close, which I expected.
I hear the BMR clears, because of its flat plate over the plenum, allowing the cross-bar to sit lower overall.
Other than that? That's all I know.
Transmission: Pro-built 700R4
Ditto on the compliments for the BMR piece. I've had a 3-point brace on my GTA for several years now. I recommend it over the others I've seen. Its a high quality piece. The flattened portion not only fits perfectly over the plenum, it actually appears to frame it perfectly. It fits unders the hood without any issues. As an added benefit, the two arms of it can be removed individually to assist with any maintenance issues (such as R/R of dizzy cap).
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
