Jack Stand placement???
Old Oct 28, 2009 | 02:55 PM
91formulaNY's Avatar
I have an 89' formula and was wondering where is a good place to put jack stands under the car??? I want the suspesion/axle to hang free. Thank you. If possible show locations by a pic if possible.
Old Oct 28, 2009 | 08:17 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Jack Stand placement???
In the rear, I always put them in front of the rear wheels, where the LCA's connect to the car framerails (just in front of this point so the LCA's can drop). On the front, just behind the front wheels under the frame rails.
Old Oct 29, 2009 | 10:36 AM
Thanks.. Thats were I put them before I read your post. TY!!!
Old Nov 8, 2009 | 09:40 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
sometimes the front frame rails are too wide. a polyurthane jack stand saddle can take up different angles and tolerances. they make "saddleS" poly also for jacks.
Old Dec 27, 2009 | 11:06 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
the front sway bar brackets and rear axle work too
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
z28joe2
Sep 28, 2015 05:54 PM
roysatikas
Sep 22, 2015 08:15 PM
ericjon262
Sep 11, 2015 06:07 PM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
