shortcuts for front strut
Old Dec 28, 2009 | 12:29 PM
4bblackbird's Avatar
do you really need to take off the front caliper to removce the front strut?
shop manual says disconnect brake hose bracket , hanes manual says remove caliper and hang. Is there any better way?
Old Dec 28, 2009 | 12:37 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: shortcuts for front strut
I beleive i replaced both of my struts with a wrench, a socket wrench, and didn't remove anything other than the brake hose bracket which is actually bolted to the shock housing, so i didn't have to do anything. Do support the a-arm though with a jack or the spring will drop out, not to mention with a jack, it makes it really simple to raise or lower it right into the shock. It's been over a year since i was up there, so do not quote me, others will chime in.
Actually, now that i've thought about it for a minute, i didn't remove anything other than what i said above because i have a good feeling i'm going to have to cut my calipers off this winter to do my brake job because of rust, so i'm 99% positive i got them swapped without removing the brakes.
Old Dec 28, 2009 | 12:44 PM
ls six's Avatar
Depends on how the hardware is installed, if the heads of the bolts are facing outward tward the caliper then they'll need to come off.
Old Dec 28, 2009 | 12:47 PM
84redta's Avatar
Guess i got really lucky, huh? But i do concur, this condition would make you take the brakes apart.
Old Dec 29, 2009 | 11:28 AM
Thanks for the info about the spring dropping out. It looks like the bolts pull out of the inside for the strut so I'll be able to do it like you did. Also, right now I don't think I'll have to remove the tire, but I suppose that does make for extra weight on the contol arm.
Old Dec 29, 2009 | 03:18 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
wow, I would certainly take the tire off...easy to do and a lot more room.
Old Dec 29, 2009 | 10:57 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
wow really? all this time i've been doing it the hard way
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
Polo Z03
Wheels and Tires
49
Jul 21, 2017 12:31 AM
redmaroz
Apr 25, 2017 07:14 AM
