only lowering an inch
Old Jan 4, 2010 | 09:37 PM
fazt4life's Avatar
Car: 1991 camaro z28
Engine: 5.7 350
Axle/Gears: stock 3.23
hey guys ive been reading all of the posts and tread and stickys about lowering but i do have one question. if i just want to drop it an inch or two do i have to buy a new torque arm and panhard bar? i have lower control arm relocation brackets but didnt know if i needed the other two things are they necessary? also should i do drop spindles, or just cut the old springs? im working on a pretty quite budget. any info helps thanks.
Old Jan 5, 2010 | 08:32 AM
BMR Sales's Avatar
Former Sponsor
Re: only lowering an inch
Hello,even just lowering your car an inch your going to need an adjustable panhard bar to get the body realigned over the axle. You will need to check your pinion angle after you get the car lowered. If it is not within spec you will need an adjustable torque arm to correct it. I would recommend not cutting your factory springs and going with a lowering spring instead. We have our lowering springs available in pairs or as a complete set of four. We have everything that you will need to get your car looking and performing like you want it. Give me a call if you have any questions about which parts you need. Here is a link to our site.
http://www.bmrfabrication.com/
Old Jan 5, 2010 | 09:41 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
"an inch or two"
There's a HUGE difference between 1 inch and 2 inches when talking about lowering. And with a 3rd gen car - 2 is about the max.
1 inch - no torque arm needed but adj panhard definitely.
2 inches - you'll need it all
Old Jan 5, 2010 | 08:12 PM
lonesomeloser's Avatar
Car: 1983 Z28
I've looked at your site many times and haven't seen springs for 3rd gens.
Old Jan 5, 2010 | 08:59 PM
fazt4life's Avatar
Engine: 5.7 350
i agree with the guy from above i havent seen any spring on your website at all. and i think i might just go for an inch. the only thing im worried about is my alignment angles afterwards...how messed up are they gonna be
Old Jan 6, 2010 | 08:32 AM
UMI Sales's Avatar
Hello
If you are looking into lowering a vehicle I would suggest going with a adjustable pan hard bar to allow you recenter the rear due to it shifts when a vehicle is lowered. UMI Performance has a wide variety of suspension parts that may met your needs. Below is a link to show you what all we have to offer!
http://www.umiperformance.com/catalo...uj7eehgvbrlgr1
If you have any other questions feel free to ask and I will be more than glad to help.
Brad
morrow
Jan 13, 2024 12:29 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
